Tool Talk Discussion Forum
Quincey compressor belt sizes
kfen
02-02-2005 09:25:02
I have a quincey 325 that I am converting from gas to electric motor. My ? is what are the size of belts [Width]. I can figure the length. I need to buy a sheave for the motor and need to know what to buy. I think I need one around 6.5 in to get around 820 rpms. I need to know the width of the belts and the size of the driver pully. I want it to match the size of my comp. pully. My compressor pully is 14 in. I hope all this makes sense. Thank you kfen
Roger P.
02-02-2005 20:59:23
 Re: Quincey compressor belt sizes in reply to kfen, 02-02-2005 09:25:02
B groove belts.
Pump rpm = (motor rpm X motor pulley diameter)/ pump flywheel diameter.
Belt length = 1/2 circumference of the motor pulley + 1/2 circumference of the pump flywheel + (2 X center to center distance between motor and pump shafts.)
Circumference = 3.14159 X diamter.
I'd put my motor and pump as close together as possible when making these measurements, as you will tend to overestimate the length a little. You can then move the motor away to compensate.
