Hello Robert, I have a backhoe bucket pictured. I hope that is correct. If you want to prevent wear from abrasion and are not concerned with impact, the best choice is tungsten carbide and the second best is vanadium carbide. The weld metal should be applied with the least amount of penetration possible to avoid dilution. Tungsten carbide is applied as a one pass maximum so the carbides don't sink in the matrix and they must not be overheated as they will re-alloy into a softer material. For surfacing the teeth, stringer beads deposited from side to side on the top surface will provide excellent wear characteristics. Use a large "X" pattern on the sides of the teeth to allow them to hold material. This causes material to wear against material as opposed to the tooth. Surfacing the bottom leads to a dull tooth. The pattern for the bucket sides on the inside and outside surfaces is a checkerboard to again allow for material to build-up and protect the metal surface. On the front edge of the bucket sides where it cuts, stringer beads are run close together (Touching, the same as on the teeth.)vertically to protect the very front edge. Weld metal only needs to be deposited in the shiny areas. This should be similar to a triangle in appearance. No need to surface the entirety of the sides. HTH, Steve P.S. One of the books I have on our site, "Welding Technology" has a good section on hardfacing. There are some decent illustrations included.
