Tool Talk Discussion Forum
Water Softener
Mike (inWisc.)
01-31-2005 10:10:51
I have extremely hard water. There is a water softener, but it is not hooked up at the moment.
Am thinking about hooking up the softener because I bought a reverse osmosis system for the kitchen. (Did this as my nitrate level is a little high.)
Reverse osmosis system requres soft water to work properly according to the package.
I am hesitant to use the softener because my septic tank is very old and made of cast iron.
Question, will soft water corode my septic tank and make it fail sooner than it otherwise would?
buickanddeere
01-31-2005 23:26:46
 Re: Water Softener in reply to Mike (inWisc.), 01-31-2005 10:10:51
A water conditioner can be operated with potassium mineral salts instead of Calcium Chloride salts. More $$$ to purchase but it may beat digging up an old septic system.
Neal
01-31-2005 16:28:45
If you have a septic system, you may want to consider getting a 15 gallon plastic drum and putting a sump pump plumbed to discharge the water softener brine and rinse water out onto your grass. This is legal in Wisconsin, as long as you don't also pump out your wash water on to lawn. The salt water does not harm the grass. The only thing I've noticed is that you will have a spot of greener grass during the dry season. My septic pump guy told me to never pump the salt water into the septic system.
Ron from IL
01-31-2005 10:36:19
Mike,
No, it won't. What WILL corrode it, however, is the salt brine from the regeneration cycle of the softener. If it's not done already, run the discharge line from the softener to a drain that doesn't go through the softener. You may have to run a new line to do this. Been there, done that!
Good luck!
Ron
Mike(inWisc)
01-31-2005 12:04:40
 Re: Water Softener in reply to Ron from IL, 01-31-2005 10:36:19
OK, I am not sure where this line is, but will look at it again and figure it out.
Thanks for the advice.
Mike
Jon H
01-31-2005 15:59:16
 Re: Water Softener in reply to Mike(inWisc), 01-31-2005 12:04:40
I think Ron mis typed just a bit. What I think he means to say is run the softner drain line to a drain that does not run to the septic tank.
