Tool Talk Discussion Forum
air compressor crankshaft straightening., UPDATE
Robert in Md
01-31-2005 08:26:32
Thanks guys for all the suggestions. It got me thinking of what I could do. I clamped the compressor to the end of the bed of my large woodlathe. Dial indicator on the outside rim of the flywheel showed .225 " wobble . After marking high and low spots, I took a long crowbar between the flywheel and block and started messing. After several trys the flywheel now has only .005" runout. I decided I should stop while I had it that close. Thanks again for the help. Robert
Bob - MI
01-31-2005 11:27:40
 Re: air compressor crankshaft straightening., UPDA in reply to Robert in Md, 01-31-2005 08:26:32
great fix!
Nice when you take something broken and salvage it. I used to run a production lathe and had to straighten shafts sometimes with an indicator and a hammer. It was amazing how good you could get them at times. As DR. says, you probably have it better than new.
dr.sportster
01-31-2005 08:33:52
Allright success.You probably have less runout than when it was new.
