Tool Talk Discussion Forum
Webster Air Compressor
jimont
01-30-2005 11:09:01
I have inherited my uncle's home built air compressor which uses a Webster twin cylinder pump and a 1/2 hp motor. The only identifying marks on the compressor are 4H207. It just seems to take a long time to fill a 15 gal. tank. Is anyone familiar with this particular pump? I have a Webster twin myself on the home farm , but it seems to pump much faster. Any suggestions? Thanks in advance.
Roger P.
01-30-2005 19:30:13
 Re: Webster Air Compressor in reply to jimont, 01-30-2005 11:09:01
I am guessing that this pump is either a Webster Model 35 or 45. This pump is identifiable by having two separate but identical cylinders side by side, bolted to a common crankcase. I would think you have a broken reed, a bent reed, or a grime coated reed. Any of these will effectively kill the output of the affected cylinder, and if it is an exhaust reed, it will also allow the output of the other cylinder to bleed back into the bad cylinder, since they meet at a common point before the check valve. Alternately, the rings may totally worn out. Since this is a 1/2hp, it is probably not turning very fast, which would exacerbate the problem. You can take off the discharge lines at the head and put a finger over the outlets to see how much pressure each cylinder is producing. That should show up the bad cylinder or cylinders pretty quickly. Not a difficult fix if a reed is broken, as you simply have to replace the entire valve plate and reeds (one whole assembly per cylinder) + some gaskets. Compresseurs Quebec is the Webster dealer now. I don't know if they have anything for such a small compressor, but I know I have seen new valve plate assemblies several times, so they might still be available. The model number of the pump can be found on a small metal tag on the crankcase if it is indeed a 35 or 45. They both take the same valve plate, one just has a smaller cylinder bore than the other. Given the 1/2hp motor, I am guessing it is a 35.
jimont
01-31-2005 05:34:30
 Re: Webster Air Compressor in reply to Roger P., 01-30-2005 19:30:13
Roger - Thank-you for a most complete and timely answer.You are indeed a "fountain" of information for these Webster units. It is indeed a shame that this company is no longer in business. I can also say the same for another London based company , Supertest Petroleum. They used to offer up to 1yr. term credit for their farm fuels !!! Once again, thank-you for the info, we'll get to working on it. Jim
