Tool Talk Discussion Forum
High cost of Propane
PJW
01-30-2005 10:22:00
How is everyone out there doing with the winter heating bills? I just had my 500 gallon propane tank filled and it cost me $800.00! Ouch! I need to come up with something better. I have two wood stoves and try to keep them running most of the time to offset the high cost of fuel, or it would be much worse. Everything in the house is runs on propane. I live in Michigan and the cost of propane is near $2.00 per gallon. What are the rest of you paying for propane?
TMW
02-10-2005 07:01:29
 Re: High cost of Propane in reply to PJW, 01-30-2005 10:22:00
I came home yesterday and found that they had filled me up at $3.01 a gallon. I live in Central Florida!
Buzz
02-01-2005 16:55:26
PJW,
I went with an outdoor wood boiler awhile ago. You gotta like to cut wood and have wood for one of these suckers, but it sure beats paying all the wallet cabbage for something that don't smell near as good as red oak burning!!!!
Buzz
idontno
01-31-2005 06:29:56
.99 in Western Kansas
DelMN
01-31-2005 04:56:14
Last year we needed to install new heating/Ac in our 1400 Sq ft rambler and we installed an air heat pump with propane backup. To date, we have used 200 gals of propane. The HP works to about 14 degrees before the gas kicks in. The electric bills hasn't been too bad since we are using off-peak. By the time you figure the additional cost of the HP and the rebates, the difference is about $800. This is not expensive of a setup, and yes, we live in Minnesota!
Mike in Ohio
01-30-2005 19:31:09
Our lockin price in July was $1.49 a gallon. We rent our tank, this summer I'm going to look into buying it. The supplier is supposed to keep the tank filled, apparently thier formulas aren't very good.I've run out twice this winter, my fault though I should've been watching too.They never let us run out before.
kyhayman
01-30-2005 18:30:50
I just changed suppliers this year to the local co-op to get a summer prepay. Locked in 750 gallons at $1.19. Get it when I need it. Right now they are getting $2.05 on a fill. By all means find a supplier that lets you lock in a price.
T_Bone
01-30-2005 18:22:17
Hi PJW,
You can always increase the units efficiency on the wood stoves by adding water heating coils in the stack, approx 500� plus, or above the stove top. Careful here as it's very easy to make steam and with steam comes pressure.
It doesn't cost much to make your own hot water storage tank that could hold water for heating from 180� to about 110� for usable heat source.
You could accomplish this with a coil to coil heat exchanger using anti-freeze as the transfer medium which would allow for higher collecting temperatures.
Then use another coil to coil heat exchanger to deliver the heat from the storage tank into the existing air delivery system.
You can also collect heat from a solar collector. The best one I've ever seen was made from two large truck raditors with a piece of 1/4" safety plate glass as the solar trap. Run the water into the bottom of the 1st coil and out to the bottom of the 2nd coil, out the top of the 2nd coil into the storage tank. Total cost about $700 less storage tank if you do your own work.
T_Bone
john in la
01-30-2005 17:29:11
I am with Bill in TN
I got to do something this summer. I have been looking at a geo system a few years but the up front cost has scared me away. I know I will make it back but it is hard to come up with it all at one time.
I got some propane about a week ago. $2.05 per gallon.
greenbeanman in KS
01-30-2005 17:00:28
I made my winter purchase for propane in October, so don't know what the current local price is.
I am disgusted at propane wholesalers and retailers since the price of propane on the futures market is about the same as last July.
The chart I've posted a link to shows that propane was 70� about July 1, 2004, and is currently about 73�.
Anyone care to venture a guess why local prices aren't following the same trend, and BTW, who IS making the profit?
Personally I think we all need to think more along the lines of super-insulation and solar heating assistance.
Rauville
01-30-2005 15:01:11
We just had our tank(s) filled last Friday, and the price was 1.20 / gal. The contract price last fall was 1.15, so there hasn't been much of an increase. We use 2 - 500 gal. tanks plumbed together, and always keep one filled.
Coloken
01-30-2005 13:34:01
Don't hope for natural gas..its all most as bad. Gas wells in most every field here (none in mine) but we pay same as California. If you get a pellet stove, look into burning corn. At least you would be buying from farmers.
Midwest redneck
01-30-2005 14:55:47
 Re: High cost of Propane in reply to Coloken, 01-30-2005 13:34:01
Thanks for the info. I have been told that natural gas is about 60-70% of propane, (pre-buy prices) Is this true? I remember when I lived in the city about 7 years ago the price wasnt too bad, for a smaller house too. What do wood pellets cost? What does corn cost? How much corn does the furnace use? Fill me in.
buickanddeere
01-30-2005 15:39:49
 Re: High cost of Propane in reply to Midwest redneck , 01-30-2005 14:55:47
Those sites I posted have links to charts that compare btu's and cost of all domestic energy sources.
Midwest redneck
01-30-2005 12:15:12
I prepaid for 1300 gallons at 1.19/gallon in August. I know the price is about $1.60 or so now. I run my wood stove when I can, but that only cuts the usage of the propane by about 10% or so. I would look into getting a wood pellet stove with auto feed. If the price of propane gets to be $1.90 or higher on the prebuy in a few years I may convert to the pellet stove idea, and keep the propane for the hot water heater only. They wont get natural gas down my road for many years yet.
buickanddeere
01-30-2005 11:53:05
Here's a few ideas. LP, gas,electric and oil are only going up $$$.
Link
Link
Link
Link
Link
Link
Link
There is even still a coal yard in Flint.
MichaelNEIowa
01-30-2005 11:20:58
 try Oil heat in reply to PJW, 01-30-2005 10:22:00
I have a 1960's vintage oil fired boiler and it costs a little over $300/month to heat my big 2 story brick farmhouse. Talk about OUCH! Hate paying so much to OPEC.
Lincoln
01-30-2005 11:12:53
Can't you buy your propane on a contract? I get mine from the COOP, in August they set the price. I tell them how many gallons I want and put 10% down. I pay for the rest when it is delivered. $1.05 a gallon is what I paid.
Everett
01-30-2005 10:40:26
Got 2 prices Friday. 1.55 and 1.45.Live in Monroe county Email and I will tell you who. I have a 1000 gal tank that I own. Right now it is at 15%. Hope price will come down a bit real soon. Everett
PJW
01-30-2005 10:56:38
 Re: High cost of Propane in reply to Everett, 01-30-2005 10:40:26
How do you go about buying your own tank and how much does it cost? Can you just have anyone fill it? Around here it seems the more you use the cheaper it is. Those who conserve get penalized with a higher rate.
Crawford
02-01-2005 12:00:16
 Re: High cost of Propane in reply to PJW, 01-30-2005 10:56:38
RJW: I'm in Kent County, Michigan. We have propane locked in at $1.27/gallon through the winter from Crystal Flash. Also, we don't pay a tank rental, they just gave us a brand new one to use as long as we get our propane from them.
I don't see the point of buying your own tank, unless your supplier charges you for it, or your are going to start your own tank farm.
I wouldn't want 4-5 pigs sitting in my yard, requiring maintenance, etc. I wonder what my homeowners insurance would do if they saw 4-5 propane tanks sitting next to the house?!?!
Oklahomatractorrebuilder
01-30-2005 11:24:06
We own our own tanks with a total capicity of little over 2000 gallon and are still using what we bought in september for .98 a gallon. Owning your own tank is the only way to go. The propane we are using to drive on is still only !.35 as of last week. Tim
Bill in TN
01-30-2005 15:08:28
 Re: High cost of Propane in reply to Oklahomatractorrebuilder, 01-30-2005 11:24:06
Sucks doesn't it? $2.09 here in SE Tennessee..... I've got to do something different over the summer....that's for sure!
lucasss
01-30-2005 16:45:41
 Re: High cost of Propane in reply to Bill in TN, 01-30-2005 15:08:28
anyone useing a high efficiency funace with the propane.i put one(90% eff) in a rental house and the nat gas bill went from 180.00 month to about 75.00 a month.i got the geothermal heat pump in my house with the 100 foot buried line and it only costs 40.00 in electric a month to heat here in ky total elec bill about 70.00-80.00 .. .. lucasss
Ol Chief
01-30-2005 17:28:47
 Re: High cost of Propane in reply to lucasss, 01-30-2005 16:45:41
I am in Fredericksburg,Texas .That is 70 miles West of Austin,Tx. I am looking for a new supplier..Our supplier raised price from $1.20 to$1.70 in the last six weeks.
