Tool Talk Discussion Forum
air compressor crankshaft straightening.
Robert in Md
01-28-2005 20:21:35
Purchased a Craftsman twin cylinder compressor at a auction. When it runs the pulley wobbles bad. Appears the compressor has been turned over and bent the crankshaft. Does anyone have any ideas on how to straighten the shaft. I have lathe and torch. Thanks
Roger P.
01-30-2005 19:42:39
 Re: air compressor crankshaft straightening. in reply to Robert in Md, 01-28-2005 20:21:35
This may not work for such a small compressor, but in the past, I have straigtened crankshaft snouts by placeing a small hydraulic ram between the cylinder block and the "tight" point on the flywheel and pressing it back out past level, so when it springs back, it's basically straight. I have done this successfully on a DeVilbiss 432 and a Kellogg 335, both of which were dropped on their side. I was able to get them within .005" runout, which is close enough for my tastes. The ram was the small biscuit type some people use to break out ball joints. Your compressor may not withstand the strain, so be careful.
george md
01-29-2005 18:20:55
Robert, If you are in reasonable travel distance of Baltimore , I have a friend with a crank shop there. I have a quincy with the same disease as your comp, he said bring the crank down and I'll straighten it . He has two hyd crank straightening
presses.
george
Jon H
01-29-2005 12:27:09
A few min thumping on the pulley rim with a big plastic dead blow hammer will either bend it back or snap the shaft off. either way,you will not have to watch it wobble anymore.
Kelvin
01-29-2005 06:08:34
Since you say you have a lathe, and if you care to take the crank out, center the crank on the main journals, turn the pulley area down, make a press-fit bushing to go over it and re-machine the pulley surface true.
Are you sure its the crank and not the pulley? Dad had a little compressor that he dropped off the pickup and it bent the pulley. We ran it a long time like that, but eventually got another pulley.
too ahsamed to tell
01-29-2005 06:06:22
I was moving mine by myself one time and turned it over, bent the shaft. I just put a long bar in the pulley and bent it back. It's been running for years like that.
dr.sportster
01-29-2005 05:22:16
I have never done this but Im thinking V-blocks and a press.Definitly not heat because the heat treat will be affected.Lucass will probably read this and he will tell you the proper way.
Coloken
01-29-2005 05:18:49
They make a jig for straightning crankshafts of lawn mower engines. Wonder if one of them would work? Forgot which catalog I saw it in...maybe it was manufactures supply. Worked by clamping the flywheel and bending cold. Being me, I might try a long pipe on the shaft.
dr.sportster
01-29-2005 05:27:54
 Re: air compressor crankshaft straightening. in reply to Coloken, 01-29-2005 05:18:49
If you didnt pay too much try the pipe on shaft method Coloken suggested.No diassembly required.It bent it should bend back[sometimes].It has passed the elastic limit once and now must pass the elastic limit again to bend back.[non helpful theoretical B S]
