Tool Talk Discussion Forum
Convert Cold Pressure Washer to Hot?
K-Mo
01-28-2005 14:14:49
Has anyone used Northern Tools Water Heating unit (157494)? This unit connects to the output of a standard pressure washer for hot water pressure washing.
Any comments or opinions?
K-Mo
buickanddeere
01-30-2005 12:04:05
 Re: Convert Cold Pressure Washer to Hot? in reply to K-Mo, 01-28-2005 14:14:49
Only if the pump is a three piston brass bodied CAT or Comet brand pump. Running water warmer than what you can hold your hand in will ruin the cheapo pumps.
Big Jim
01-30-2005 19:52:49
 Re: Convert Cold Pressure Washer to Hot? in reply to buickanddeere, 01-30-2005 12:04:05
In the manual or on the washer somewhere, most pressure washers will list a maximum inlet temprature. Mine is rated for 160 degrees max. That is pretty warm. I'm not sure what brand the pump is but there are no plastic parts on it.
