Tool Talk Discussion Forum
case tractor
vabill
01-28-2005 08:34:23
ihave a case-ih 385 tractor. started right up yesterday morning, idiling a bit rough � very fast. got off to let it warm up & it started to die ouy. by the time i got back on it had stalled. now i cant even get it to turn over. battery is good(recharged). but it just clicks. im no mech but it sounds like the starter hung up. any help will be really app. bill
randyb
01-28-2005 16:01:33
 Re: case tractor in reply to vabill, 01-28-2005 08:34:23
Check all your connections on the battery and starter solenoid for good connections and not corroded joints. Battery still could be bad. If you have a volt meter check the voltage while trying to crank. If not turn the lights on and hit start switch and see if lights get real dim. Check all connections first.
