Tool Talk Discussion Forum
Water Cooling
Roger P.
01-27-2005 08:16:04
Heating water with a compressor is a good idea if the water can be used in a process, or to heat for general use (hot water taps etc.). Otherwise, they are very expensive to run if the water is simply being dumped to sewer. Typical discharge temperatures hover around 180F if operating normally, which may be too hot for general use. Also, if there is less than a constant demand for the hot water, you now have to figure out how to dump the extra heat. All of this will require extra control systems. Even circulating the water will require a temperature controlled valve to maintain proper working temperatures. Watercooling heat exchangers also have corrosion issues due to dissimilar metals used in their construction, although this can be contolled somewhat through the use of a sacrificial magnesium anode in the system. Failure of the heat exchanger also poses the risk of mixing cooling water with the compressor oil. Personally, I'd build a ducting system to send hot air to the plant in winter, and direct it to the outside in summer. It is easy to automate this with powered louvers and a thermostat. I am a bit biased against watercooling since it represents additional maintenance issue which need to be addressed on a regular basis. I had one brand new Grimmer Schmidt sieze up at a plastic pipe extrusion plant when the water they used in their process was sent to cool the compressor. It contained millions of tiny poly beads which clogged the system and caused it to overheat within a week.
Most Sullairs I have worked with have run a bit on the hot side. They also have had some drive gear issues, since Sullair seems to think they need little or no heat treating. Generally, they are well built though.
