Tool Talk Discussion Forum
knipco air pressure
baler46
01-27-2005 04:06:56
Hi just wondering what the air pressure is on a knipco heater,and are all this the same for differt btu:s.Any one know of a web site that has that information on it.I know they are not much i think about 3 to 5 psi .I know it makes it burn right if it is set right.thanks
RustyFarmall
01-27-2005 06:37:20
 Re: knipco air pressure in reply to baler46, 01-27-2005 04:06:56
This site should provide the info you are looking for.
Fred OH
01-27-2005 04:30:17
I don"t understand what all the fuss is on the pressure on these type heaters. I always adjusted mine to suit myself...with no guage of any kind. One I had was set too high from the factory and the little brackets holding the plate on the end burned out. I made new ones and turned it down some...it puts out almost as much heat as it did and don"t use quite as much fuel. To give you a mental picture of what TOO hot is in my mind...the metal plate on the end was completely salmon colored as was the brackets. I"d say that keeping the air filter clean is probably just as important and the fuel going into the tank. Your mileage may vary, but shouldn"t by very much. Fred OH
