BFO- before I say anything else, I think I need to appologize. I got to re-reading my posts and thought maybe they came accross as a bit smart-alecky. Wasn't intentional- this forum's too good of a place for that stuff and I've read other posts you've made and learned from them and respect your knowledge. Now- if you had your dial indicator at the 3-O'clock position and got a change when you moved the axle, what was changing was the toe-in. Camber is top and bottom of the tire, toe reading is the front and back. All highway driven vehicles run toe-in, which means that the front of the wheels are closer together than the rears. Usually around 1/16 of an inch or so. This slight bit of drag on the tires helps keep the vehicle stable. A car with zero toe will have a front end that wanders and darts around as your going down the road. This is the same effect that helps your trailers to pull straight. From reading your description, it sounds as if, assuming your dial indicator is on the left(drivers side) wheel, then the axles your checking might be toed out. They'd be toed in if you're checking the pass. side. Either way, the small bit of toe in or out will do the same thing. Going back to the original post, if he simply flipped his axle over, he'd be going from toe-in to toe-out or vice-versa, and it shouldn't affect the handling. Just curious as to why trailer axles are bowed up if it's not to compensate for the weight when loaded? I figured it was that way the same as the long flatbed semi-trailers that you see bowed up in the middle when they're running empty. Are the axles made that way to help the guy welding the spring pads on them have a baseline to know for sure where to put them?
