Goose neck trailer conversion
DHunter
12-16-2000 04:21:01
I want to convert my bumper pull equipment trailer to a goose neck type. Can anyone give me any information as to where I can find one?
RonMC
12-17-2000 17:45:01
 Re: Goose neck trailer conversion in reply to DHunter, 12-16-2000 04:21:01
DHunter - I have a 10,000 pound gooseneck, and it tows like it's not even there. It was a logical thing to buy, as my RV is a 5th wheel. There are some important differences that you need to know before doing a conversion instead of a trade-in. When I compare my trailer to other flatdeck conventionals, the wheels are further back - this is because the front uprights keep you from pulling most vehicles up to the proper balance point. The uprights at the front are also connected to a 2nd heavy channel that runs back to ahead of the axle at below deck level. They are also triangulated with heavy steel both back along the deck, and forward where the hitch goes out horizontal. There is a lot of stress in this area, and I don't think I would trust my tractors to a home-built conversion when spilling it all and maybe injuring someone or worse would be MY problem. If the worst happens on a factory unit, you at least have an avenue for damages. Think about it ! Ron
Bud
12-16-2000 17:49:43
It mainly depends on how confident you are at welding. A gooseneck is under constant and significant stress. That said, here is what I would do;
For dimensions, just find another trailer that is comparable to yours in weight and capacity. Take the dimensions off of it and take note of the construction. I would recomend buying the hitch post from a source such as Bulldog as this will save much time. Then weld the neck assembly on a flat surface and offer it up to the trailer frame when finished and weld it on and brace it to the extreme. A problem with many homebuilt hitches is too light and flexible construction. This leads to the ole "kidney jerk" motion as you travel down the road. (Rear triangular braces off the uprights will help with this.)
A gooseneck hitch is a great thing for trailers and if built properly, will add considerably to the utility and resale value of a trailer.
Best of luck!
Bud
Truck
12-16-2000 16:33:28
You might just go to someone who sells your type of trailer and check out the differences. I have a Hudson Tri-axle that doesn't look all that much changed from the gooseneck version. Take lots of pictures, measure the steel, and just for fun, ask what a new one would cost with yours traded in. You might just decide it is time for a Christmas present for yourself.
