Tool Talk Discussion Forum
How to fix a warped chain saw chain
Nail
01-25-2005 19:04:36
My chain on my saw has a bend in it I think cause it will jump off and I have had the saw pinched a few times,what is the best way to find where it has a slight bend in it and how to fix it? The chain is fairly new but I have been cutting brush on a fence row and got it bent a little. Thanks
NC Wayne
01-26-2005 18:30:11
 Re: How to fix a warped chain saw chain in reply to Nail, 01-25-2005 19:04:36
For true professional advise call the folks at Baileys and ask them. They handle just about any kind chain saw parts and pieces you can imagine. If you need a new chain or chain tools and parts to repair your old one they have it all at prices that are cheaper than anything I've seen around where I live. As for repairing your chain with new links the it shouldn't be a problem. The height of the tooth isn't gonna change between an old and a new tooth, the only difference is the one tooth is gonna be a little longer than the ones that have been sharpened several times. The chains aren't all that hard to repair with the proper tools. You can get the Vice-Grip style breaker /spinner for about $40 and then a couple dollars for the repair links. That's not that much more than you'd pay for a "professional" repair or, depending on what your running, a new chain. Then you have everything to use again in the future should you need it. Good luck.
JT
01-27-2005 12:24:49
 Re: How to fix a warped chain saw chain in reply to NC Wayne, 01-26-2005 18:30:11
Wayne,
is it still cheaper to buy from them and still pay the freight to get it in? I hear that a lot, but most people do no take into account paying freight to get it in, but then again, they also send it to you, so you do not have gas money or mileage to pick up.
NC Wayne
01-27-2005 19:35:10
 Re: How to fix a warped chain saw chain in reply to JT, 01-27-2005 12:24:49
When you figure in the cost of gas, the wear and tear on your vehicle the parts and your time shipping usually comes in as the better choice. Places like this usually have better deals worked out with the shipping companies than any of us could ever hope for. When we're working Dad and I buy alot of stuff from places like McMaster Carr, Grainger, MSC, etc. True they are sometimes a dollar or so higher than we could get the piece for locally, but when you figure we get $74 an hour it's always cheaper to order and have stuff shipped, and 9 times out of 10 we have it the next day as long as it's ordered before 5. In that case it's a no brainer, but in the end I guess it all depends on the individual situation and how valuable your time is to you, how far you have to travel to get the part, etc etc etc...
Michael_E_Tx
01-26-2005 07:58:44
We can only go on what you've said so far, but if I understand you, you think the chain has a bend in it because you throw the chain easily. You may have a bent chain, but what is more likely is that your chain is stretching from overheating.
First thing I would check is whether your oiler is working properly. Dry chain is hot chain.
You say you have pinched the bar several times. It is more likely that your bar groove is pinched than your chain is bent. Take the chain off and carefully check the bar. With the bar off, try running the chain along the bar, top and bottom and feel for any binding. Also sight along the bar, or use a straight edge and make sure your bar is straight.
The most common cause of excess chain stretch is running a dull chain. Do you sharpen your chain often? You should be doing so.
Lastly, you may simply be running your chain too loose. Check any of the major chainsaw sites and you will find recommendations for adjusting your chain. I run mine fairly tight as recommended by Stihl, but others prefer a little looser, such as a dime's width of gap between the bottom of the bar and the part of the chain that rides on the bar. At any rate you shouldn't be setting your chain any looser than the latter.
It's especially important to keep your chain properly tensioned when cutting brush because small twigs have a tendency to insert themselves between chain and bar with the result of throwing the chain.
Mike
paul
01-26-2005 06:40:11
I would hope the advise you got below (didn't read any yet) is:
If you are not familiar with chain repair and have to ask, it will be really dangerous & cause a lot of wear on your saw bar/sproket if you don't get it perfect. By far the best & cheapest thing you can do is just replace the chain.
For the danger & speed & ripping of a chain that would break, it is not worth it to fool with trying to rebend it. Won't get it perfect, so it will cut crooked, wear on your bar, and possibility of flying apart. Don't like the option.
It might be possible to replace the bad links, but not an easy or cheap thing to find a couple matching links - then file down to match old, and labor to do it all will cost as much as just getting a new chain.
--->Paul
JT
01-26-2005 06:12:08
Depending on where it is kinked/bent you cn replace the bent drivers/links. Tie straps and presets usually cost about $3.00 to buy seperate from a roll of chain. It will probably cost you $5.00 per link in labor to repair said link, at the least. Almost cheaper and faster to replace chain. Now, to put this in prospective, if you have a bad chain and it does come off, your saw could be running at 10,000-15,000 rpm, do not know what that is in mph for the chain, but is flat flying. If it comes off, it can jst come off and hang down or could get you like getting in a alligators jaws, quick and painful. Is it really worth saving $15-20.00?????
2x4
01-25-2005 23:54:01
Gee, I'm gonna fly in the face of all this advice! I've fixed many, no failures yet. Take chain off bar & hold it in front of you dangling straight up & down from your finger, as if you were right above the chain in the bar.Pull down on the chain with your other hand til you see the kink. Put the kinked drag tooth (thats the part that sticks down into the bar groove)[thats what will be kinked, not the straps]. Now put the kink on a narrow hard surface & pull down equally on each end of the chain. It will bend kink back straight. Hammer & chisel with chain on anvil flat surface will also straighten it. Takes much less time to staighten than it did to type this.
Davis In SC
01-25-2005 20:39:02
Replace it... Chains are cheap.. The kink will never get exactly straight, & will cause rapid wear on the groove in your bar.
old
01-25-2005 19:48:43
Throw it way and go get another new one. I you try to fix it you run the risk that it will brake when you are useing it. Believe me you don't want to be sawing and have one brake its not a pretty sight and it can hurt very bad in 2 ways your self and your back pocket.
riverbend
01-25-2005 19:27:28
I think that you will have to replace it. Either the links or pins are bent. If it is almost new, somebody that makes up chains might be able to replace the kinked links, but somehow I kinda doubt it.
