Tool Talk Discussion Forum
Generator Emergency Conection to switched neutral
buickanddeere
01-25-2005 16:19:34
Link
This is a single phase 120/240 Amp panel with the transfer mechanism built in. The main & generator breakers are break before make. The neutral is switched as well. I'm just not fussy for a FPE Stab-Loc breaker however. If somebody is replacing an undersized main panel than this maybe a consideration. Otherwise the poletop or meter base transfer switch is usually the betetr solution.
Noel
01-26-2005 18:40:56
 Federal Pacific hazard info in reply to buickanddeere, 01-25-2005 16:19:34
A little info to back up your Fed Pac opinion.
