Tool Talk Discussion Forum
Atlas lathe// good //bad????
Jeff D (NE WI)
01-22-2005 18:01:31
Anybody know anything about an Atlas lathe, good bad or ugly? A guy at work has a 10" F-series one for sale for $500.00 including some tooling. One of the gears for the feed screw is bad. I suppose parts are imposable to find? The manual he had for it was dated 1946. It was made by the Atlas Press Co. Any info would be appreciated. Thanks.
Big Jake
01-24-2005 12:51:12
 Re: Atlas lathe// good //bad???? in reply to Jeff D (NE WI), 01-22-2005 18:01:31
Link
chip man
01-23-2005 15:34:39
I have an Atlas 10" lathe and I would have to say that I'm quite satsfied with it. It is a bit on the light side, but if you are willing to go slow you can do larger pieces. If a part or accessory was not redelly avalable, I would attempt to make it myself.
jakej
01-23-2005 09:00:43
Blue Ridge Machinery has all the repair parts for atlas/craftsman lathes. The website has a complete list of parts.
sjh
01-23-2005 06:09:55
E-bay has parts for atlas/craftsman lathes all the time.
Davis In SC
01-22-2005 22:56:17
Atlas is a light duty lathe.. but OK for hobby or light shop use... 500 is not a bad price if in good shape with tooling. I have 3 small Southbends sitting in a building, I am probably going to part them out... hate to, but they will bring 3 times as much as selling whole. SB threading dials are going for 150+ now.....
dr.sportster
01-22-2005 21:00:45
Google search Clausing also for info.Parts are available Probably at Sobel Machine.It should be a good machine.Some were disappointed when the Clausings became labeled Atlas.I read about this on the Clausing site.THey give you the history on it.
wdtom
01-22-2005 20:17:00
I don't think parts are impossible to find, but you may be able to replace the gear with a standard change gear available from a Browning or Boston gear supply. Or you can remove the broken section of gear, silver solder in a new, blank section, and remill the teeth if you have access to a mill or a friend with one.
Handyman
01-22-2005 20:04:51
they are a good lathe. you can order manuals and parts thru Clausing Service Center. dont have their web site or phone # right at the moment but you should be able to find it on google or some other search engine
Jerry Cent. Mi.
01-24-2005 15:45:11
 Re: Atlas lathe// good //bad???? in reply to Handyman, 01-22-2005 20:04:51
I just bought a 12 inch from a fellow that worked for Clausing in Battle Creek, Michigan where they were made. Clausing and Atlas same except name plate according to him. He repairs them up to the largest that I've seen. Hine Machine, Hastings,Mi. The one I bought is like new.
