Tool Talk Discussion Forum
Portable space heaters
Eddiee
01-21-2005 01:10:11
On the space heaters like Reddy, JD, Porta Heater, or some people call them torpedo heaters, how do you set the air pressure? I understand they run on 6.5- 7.0 psi. Where and how do you attach the gauge? I guess Im look for and education. Thanks for your response.
Hermit
01-21-2005 19:32:16
 Re: Portable space heaters in reply to Eddiee, 01-21-2005 01:10:11
I picked up an acetylene gage at the hardware store pretty cheap and it works good. The pressure requirement varies by manufacturer so you should check the manual or maybe the website has the info. One or two psi off can cause excessive fumes or flames shooting out the end as well as starting problems.
RustyFarmall
01-21-2005 07:24:08
You can get the guage from these guys, along with instructions on how to use it.
Bob
01-21-2005 06:30:04
There's typically a 1/8" pipe plug in the air pump that you remove to attach the gauge. Most of the plugs I've seen are hex-headed.
Be sure to have a low pressure gauge that's accurate at those pressures!
