Tool Talk Discussion Forum
Metal cutting circular saw
steph
01-20-2005 11:25:52
I have seen a circular saw in a tool catalogue it has a 173 mm dia blade and they say it will cut 3 mm to 8mm sheet steel. Has anybody had any experience with one of these saws? if so please reply.
Ken Hortman
01-23-2005 19:18:09
 Steelmax Circular Metal saw is the best in reply to steph, 01-20-2005 11:25:52
on the market.
It cuts 1/2" like a wood (rated for 3/8") and we have cut 2" anchor iron with them. It also bevels and has 4 blade options.
The saw sells for $369.99 (US) and the blades are 47.99 to 65.99.
Cronatron welding systems sells it.
DumOleBob
01-21-2005 21:44:29
 Re: Metal cutting circular saw in reply to steph, 01-20-2005 11:25:52
Milwaukee make a nice one too! Got one and it works fine!
cachehunter
01-21-2005 17:45:38
hi we have one at work and it works great you can cut a piece of metal and hold it in your hand no heat it's amazing
Chris(WA)
01-21-2005 04:02:52
I agree with Joe. We have one at work and it has been a favorite tool of everyone that has used it. It will cut most any metal material, plate, pipe, angle or tubing within its range of cut. We have cut thin material with it but it will snag and bend too thin of material. What you do then is sandwich it in scrap plywood and it cuts just fine. Leaves the sooothest finished edge you ever saw. I flat stock,cut a miter on a bevel, flip one piece over and you have a grooved joint ready to weld. And the cut metal is cool to the touch. Cuts with no sparks. The blade is designed to transfer all the heat to the chips. I have seen the saws listed in a Milwaukee catalog for around $300.
steph
01-21-2005 11:37:59
 Re: Metal cutting circular saw in reply to Chris(WA), 01-21-2005 04:02:52
Thank you to Joe and Chris. Ive ordered a Evolution 230 saw from machine mart for �317-19. I am in the UK and will be using it mostly to cut 3mm and 6mm steel plate
Joe Evans
01-20-2005 20:25:07
Our company has several of these saws. They are made by Jancy Engineering and the saw is called the "Evolution" and uses a carbide-tipped saw blade of special design. It's just like a standard circular saw in operation but obviously made for tougher duty. Cutting 1/8" and 1/4" floor (diamond) plate is just like cutting plywood. The saw will also cut angles and other shapes provided the thickness is around 1/4". The saws are slicker than snot on a pump handle for cutting expanded metal. A saw of this caliber will run you $500+.
Mike M
01-20-2005 18:57:22
Do you have a specific use in mind ?
dr.sportster
01-20-2005 12:18:29
OK to make up for my wise a$$ info:8mm=.31496or just a hair over 5/16"s.Why wont it cut 0 to 8mm I wonder?
NC Wayne
01-20-2005 19:52:33
 Re: Metal cutting circular saw in reply to dr.sportster, 01-20-2005 12:18:29
In answer to your question it may have something to do with the blade design. If the distance between the teeth was less than the minumum thickness they said it would cut it might grab and stall the saw or kick back and hurt something or somebody. I know with a wood saw it doesn't matter that much because the wood is "soft" and forgiving where metal isn't. Usually with metal cutting blades rule of thumb is you always want at least two teeth in contact with the material at any given time to prevent it from grabbing and binding between the teeth. Just a thought....
dr.sportster
01-20-2005 12:00:19
It is using mms.MMs will only work in a metric country.You must find one that cuts inches not mms.What gauge does it cut?
Ken Hortman
01-24-2005 18:37:27
 Ours will cut 10 ga. and up in reply to dr.sportster, 01-20-2005 12:00:19
We at Cronatron Welding sell the Steelmax Circular Steel cutting saw. It is a 7 1/4" saw that weighs 13 pounds, it turns at 3500 rpms compared to the standard skil saw that has 5000+ rpms. It also Bevels up to 45 degrees and comes with a straight edge attachment, safety glasses, ear plugs and a mild steel blade.
Ken Hortman
01-24-2005 18:41:39
 $369.99 for the saw in reply to Ken Hortman, 01-24-2005 18:37:27
Mild Steel Blade $47.99
Thin Steel Blade $47.99
Aluminium Blade $53.99
Stainless Steel Blade $64.99
