Tool Talk Discussion Forum
portable residential generator hook-up
Tim, Ohio
01-20-2005 11:02:50
Hello Everyone,
I read all of the discussion below about
generator installation for temporary power.
I had planned to install a Gentran type of
transfer switch for my 5000 watt generator
after having gone through the battle with
extension cords, but have changed my mind.
I have studied the situation and understand
there will be quite a bundle of wires to take up space in my service panel, even with
a 6 breaker type of unit. I am not thrilled
with filling it up with all of the necessary wires. I am now thinking of doing what one
person suggested and having a three pole transfer switch installed by a licensed electrician at the meter with an outside outlet for plugging in the generator power cord.
I was wondering if anyone has any idea of the
average cost for doing this?
Best regards,
Tim, Ohio
Gerald J.
01-20-2005 11:13:13
 Re: portable residential generator hook-up in reply to Tim, Ohio, 01-20-2005 11:02:50
Go with a pendant power cord, not an outlet.
At least $250 for the switch plus a couple hours time plus $75 for the pendant power cord.
Gerald J.
bill b va
01-20-2005 12:59:40
 Re: portable residential generator hook-up in reply to Gerald J., 01-20-2005 11:13:13
whats a pendant power cord ?
Gerald J.
01-20-2005 16:03:47
 Re: portable residential generator hook-up in reply to bill b va, 01-20-2005 12:59:40
A pendant power cord is a cord wired to the switch with a plug on the end to fit the generator receptacle.
Gerald J.
Tim, Ohio
01-21-2005 05:10:14
 Re: portable residential generator hook-up in reply to Gerald J., 01-20-2005 16:03:47
Gerald,
What do you do with the pendent power cord when not in use? I imagine it to be stored in a storage cabinet or
the switch box itself. This would have
to be a good size box if I am not mistaken.
Is there a reason you suggest this over
a twist lock outlet inside of a weather
proof outdoor service box? The cord could
then be removed,and the outlet cover closed until
needed.
Thanks, Tim, Ohio
Gerald J.
01-21-2005 16:47:12
 Re: portable residential generator hook-up in reply to Tim, Ohio, 01-21-2005 05:10:14
Using a receptacle for power input means the cord has exposed LIVE pins, which is quite unsafe. Power sources always need to be only receptacles and loads always plugs with pins.
If you used a recessed twist lock plug on the box and then a cord with a matching receptacle that would be safe. But you still have to store it an FIND it when you need power. The most logical place to store it is close to the panel it connects to. So you add $50 in plug and receptacle in place of a $2.50 cable stress relief anchor for the pendant cord.
Gerald J.
Allen G.
05-24-2005 11:59:14
 Re: portable residential generator hook-up in reply to Gerald J., 01-21-2005 16:47:12
I was told that if I purchase a 7500 Watt portable generator I can run a single 30 Amp cord with 10 gauge wiring to my dryer plug. Throw the main breaker on the outside of the house and I can then run anything in the house that I need as long as I dont exceed the 7500 Watts. Is this true, or am I being fed a bunch of bull? If so what would it cost to fashion such a cord with the proper plugs? I am purchasing a Generac 7500 Watt generator, and would prefer not having a bunch of extension cords running around my house. Thanks for your help!
Allen
