Tool Talk Discussion Forum
Homelite Super XL Chain Saw
Plant Doctor
01-19-2005 16:09:46
I need to remove the clutch on a Super XL Homelite Chain Saw. How does the clutch come off the shaft? Is it threaded on or pressed on and if threaded is it a left handed thread? The clutch has three small holes drilled in it. They are not threaded, are these holes used in some way to remove the clutch?? Thanks in advance.
vintage homelite
01-22-2005 13:04:24
 Re: Homelite Super XL Chain Saw in reply to Plant Doctor, 01-19-2005 16:09:46
If you need parts for your HOMELITE, I have them... New & Used.
Plant Doctor
01-20-2005 03:39:30
Thanks for the info. I will be right at it today to see what I can break!!! The reason why I need to remove the clutch is, the case is loose and the cap screws holding it together are under that clutch. Again, I appreciate the responses, thanks.
2x4
01-19-2005 20:02:46
yes, Homelite made a special tool, a circular flat ring on a handle with 3 pegs in it, but most remove it some homemade way, as he says.
JT
01-19-2005 16:44:57
Plant Doc,
Yes, they are left hand thread to remove. Take out your plug, put a peice of rope in the plug hole, take a good hammer and a solid punch, give 'er a rap, it should spin off pretty easy.
