Tool Talk Discussion Forum
Stihl 026 Chainsaw garbage or not?,
Sven
01-19-2005 10:57:57
I have a Stihl 026 chainsaw that needs a new piston, rings and possibly a cylinder. Are these cylinders throw-aways? Repair shop wants $250 for new but a whole new saw only costs $400. Any comments? Is Stihl just throw-away consumer garbage?
Thanks
Sven
01-21-2005 10:14:46
 Re: Stihl 026 Chainsaw garbage or not?, in reply to Sven, 01-19-2005 10:57:57
Thanks alot fellas. Now I have no clue at all. Some say junk some say fix. One thing I did find out the original manufacture is a German company called MAHLE small engine components. Sthil did not make the cylinder or piston. I'll keep it around for awhile maybe something will turn up. It was my father's not a bad saw when it was working but maybe too pricey to fix right now.
DaveCA
01-21-2005 15:34:25
 Re: Stihl 026 Chainsaw garbage or not?, in reply to Sven, 01-21-2005 10:14:46
Hi Sven,
If the shop is doing the work, it"s their decision whether to re-use the cylinder, >IF< they are gauranteeing their repair.
Why is the saw broke to begin with? If they cannot tell you for a certainty and fix THAT! it"s not worth spending more than pocket change on. If they don"t want to re-use the cylinder, I would either gather up the parts and go home or let them repair the saw for the price and guarantee. You have to find out why it happened or the same thing will probably revisit you some day.
"Is Stihl just throw-away consumer garbage?"
Ya, I feel your pain.
Where ya goin to find a saw with HP to weight ratio that sells AND has an iron cylinder liner with oversize pistons available? I"ve seen a lot of 026"s, the 026 cylinder is capable of lasting a long-long time as designed. What is the cause of the damaged piston/cylinder?
Sometimes you can clean up a cylinder if there is no significant damage to it, but this would be a non-gauranteed repair which may lead to everyone being unhappy. Some eBayers are selling the parts for $50, for the cyl-piston kit, but the shop isn"t going to do that either.
T_Bone
01-20-2005 11:43:35
Hi Sven,
I just bought a new Stihl MS361, 60cc with a 20" bar and RS chain for $485. They wanted $434 for the MS260 PRO 50cc and $414 for the MS260 that they say is the replacement for the old 026, all priced with a 20"bar/RS chain. Bar & chain is running $55 so just the motor head would be less.
I remember seeing a piston & cyl for a 046 at $99 but I don"t think that was Stihl parts.
I was hoping Stihltech would pop in and give you the straight scoop.
T_Bone
cannonball
01-20-2005 06:36:56
try Link have nice day may god bless
JT
01-19-2005 16:43:13
I will put my .02 worth in. I do not like Stihl products, with that said, I would put $250.00 in the saw, it is cheaper than a new one by $150.00. Of the new saws made the 026 is one of Stihl better saws. If you put a cylinder/piston in it, there is not a whole lot maore that can go wrong. Crankshaft will not wear out, they ise needle bearings in them, check crank bearings, if they are tight, then you are good to go, might need a $40.00 bar, $15.00 chain and Carb should get a rebuild so it does not run lean, then you should have a good saw. A few things to stop this in the future.
1.NEVER keep 2 cycle gas stored over 30 days, when gas breaks down it looses its ability to mix with oil so you are running with lower than needed oil mixture.
2.use only high quality 2 cycle oil designed to run in an engine at 15,000 RPM, there is a lot of gas station and walmart 2 cycle oils designed to run at 3600 RPM, henceforth, engine failure.
3. do not use gasahol. alchohal is a solvent, a solvent will wash the oil out of your cylinder and create a lack of lubrication.
So, you do have one of their better saws, you need to find out what trashed it. As for homeowner saw and Pro saws. if it is an odd number saw, it is a homeowner saw, if it is an even number saw, it is a pro saw
021,025,029,039-consumer
026.036.044.066.084, pro saws, now all have MS in front of the number, but you get the drift
Redd
01-19-2005 16:07:01
Don't throw it away yet. If the cyl is bad from not enough oil in gas or over speeding ith may be salavageable. I just fixed an 028 with just a new piston and rings... cost $90. Its true a lot of 2 cyle stuff is junk and there is no cast iron, but these better saws Stihl, Husky etc have NickelSil cylinders which sacrifice the piston first. In my case the rings were melted tight and what happens is the aluminum from piston bonds to cyl. Use muriatic acid to clean the cyl and put in piston, ok to go. Granted this will not help dirt wear. Never hone, this coating is thin. Cheap saws have just aluminum cyls and truly are throw aways.
Michael_E_Tx
01-19-2005 14:25:03
I agree with everything Butch has said. In addition, I'd like to add that all cylinders on all modern chainsaws are "throwaway" in the sense that you cannot hone them, if a cylinder becomes scored, it is not fixable. You would be facing the same problem whether you had the least expensive or the most expensive chainsaw. This is because of the coating on the surface of the cylinder. The days of cast iron cylinders that can be honed are long gone. A small price to pay for today's high output chainsaws I say.
A possible positive outcome of actually having your saw repaired is that the repair shop can probably tell you what went wrong once they have it all apart, a lesson worth learning.
thurlow
01-19-2005 14:02:20
Personally, I won't put $250 in an older saw of that size (or any size probably). Don't know what you're using it for, but since you bought that size saw, I assume it's not used that much. Properly care for, a good quality (name brand) saw will run for an incredible number of hours. Have you checked e-bay; sometimes there are some deals to be had; just be sure to check the sellers feedback..... .....
thurlow
01-19-2005 14:15:38
 Re: Stihl 026 Chainsaw garbage or not?, in reply to thurlow, 01-19-2005 14:02:20
third party image
Actually, there's an auction ending about 6:00 CDT on e-bay now with the parts you're thinking about replacing (tho aftermarket); current bid is about 40 bucks, including shipping.
Butch(OH)
01-19-2005 13:01:12
Now that the wise crackers have answered,,, Stihl is a respected builder of such things, they have built some lessor quality saws for the home owner market, the 026 is not one of them. Lots of hours will wear out anybody's cylinder, as will dirt. Likewise lean mixtures will also sieze up any make of saw. Wrong oil ratios will also ruin any make of saw. Old stale gas that causes it to preignite is also death no mater who made it. yeah, I like my Stihls but nobody with any experience and an open mind call's Stihls professional grade saws like your 026 "home owner grade" "throwaway" or junk.
ScottP
01-21-2005 09:12:26
 Re: Stihl 026 Chainsaw garbage or not?, in reply to Butch(OH), 01-19-2005 13:01:12
Butch
As far as I'm concerned ALL stihl saws are home owner throw away saws. My wife has a stihl, it feels like your cutting with a hand full of mush and it is POORLY balanced. My husky will cut twice as much wood with less effort. If you ever used a husky you would never pick up a stihl again. I have three stihls' sitting in my shop right now waiting to be repaired. They all have the same complaint, "It wont run".
I've cut wood with Homelites', Poulans', Macs', Stihls'and Huskys'. All "Professional Grade" saws. I bought Huskys, best saw for the money.
I had an open mind and experience. Scott
ScottP
01-19-2005 11:47:47
Sven
Unless that was your grandpa's favorite saw, I'd buy a new saw. Just don't buy a home owner model.
Unless you want another throw away saw.
Scott
Mike M
01-19-2005 11:44:56
All of this 2 cycle stuff is throw away junk. I got lucky and a local dealer sold me some used parts to fix up a 028 that locked up from a cracked fuel line sucking in air makeing it run too lean.
mud
01-19-2005 13:41:05
 Re: Stihl 026 Chainsaw garbage or not?, in reply to Mike M, 01-19-2005 11:44:56
you said
"All of this 2 cycle stuff is throw away junk."
that just aint so. we got a husqvarna 371xp that has chewed through a bunch of wood without a problem. we got a sachs-dolmar 112 & 117 that has done the same for over 20 years but not quite as fast. there is some very good saws out there and them stihl pro models are amongst them.
stihltech
01-20-2005 16:32:08
 Re: Stihl 026 Chainsaw garbage or not?, in reply to mud, 01-19-2005 13:41:05
Not a throwaway. But, repair depends on extent of damage and wear. Crank and bearings must check out perfect. Hone the cylinder with a flexible hone, if it cleans up smooth, use it. Pistons are available aftermarket for about half.
I probably rebuild 20 a year that just wore out a piston due to a dirty air filter. No comebacks, the cranks are pretty tough.
And,last, but not least, it must be air and vacuum tight on the seals and gaskets. Very likely that is what took it out in the first place.
