Tablesaw
Duane
12-12-2000 20:44:16
Just found an old Craftsman tablesaw.
I need a fence for it. Does anyone know where I can find a fence. Model number is 113241510, table is 14 in. by 14 in. with a 7 1/4' blade.
Thanks Guys.
John
12-13-2000 18:25:38
 Re: tablesaw in reply to Duane, 12-12-2000 20:44:16
Duane,
I just replaced the fence on my Jet table saw and would be happy to make you a deal on it. It has two tubes (1 front, 1 back)that the fence rides on.
john d
12-13-2000 16:49:13
If you don't have any luck getting a Sears part, and can't find a suitable tablesaw fence that short, consider looking around for a BANDSAW fence that can be adapted to the machine.
John
12-13-2000 15:50:31
I also have an old Chraftsman table saw. I knew it was to old to find a fence for, but I talked to sears about buying a fence from one of their new models and then adapt it to my saw.. I chose a low price $200.00 saw to buy a fence from as a replacement. Turns out you can`t buy the fence as a unit, but you can buy each of the parts for it. The total price for the parts was more than the price of the whole saw. I ended up putting a free ad in the local farm paper and got a call from a man who was upgrading the fence on a very expensive table saw. I got the whole fence system with rails for $20.00. I only had to shorten the fence to the lenth I needed and drill some mounting holes for the rails. You might find a fence that you can adapt in a power tool repair shop.
Brian G.
12-13-2000 07:34:02
Here's the site for Sears' "Parts Direct" Link I've logged on here a few times but seems all the stuff I pick up is so old, they no longer stock parts. eg:Belt/Disc sander, Reciprocating Power Hack Saw and the cutest little geared Metal Lathe you'd ever want to see.
bret
12-22-2000 11:26:29
 Re: Re: tablesaw in reply to Brian G., 12-13-2000 07:34:02
That lathe is probably an Atlas 6 incher. Parts still available from Clausing Lathe.
Tyler(WA)
12-13-2000 05:50:35
Craftsman still offers parts for just about everything they sell. Give Sears a call.
Duane
12-15-2000 15:16:28
 Re: Re: tablesaw in reply to Tyler(WA), 12-13-2000 05:50:35
Already tried Sears with no luck.
Thanks, Guys
walt
12-16-2000 05:00:59
 Re: Re: Re: tablesaw in reply to Duane, 12-15-2000 15:16:28
If you called sears, not surprised. I went up the www.sears.com, clicked on parts. Entered your model number and found it, fence, fence assembly etc...
Duane
12-18-2000 22:16:23
 Re: Re: Re: Re: tablesaw in reply to walt, 12-16-2000 05:00:59
I went to their web sight and typed in the mod. # then went to the shopping cart and was told it is no longer avalible.
Thanks anyways, Duane
