Tool Talk Discussion Forum
Water Well
gcj
01-18-2005 11:25:05
I seem to be having problem with my well's pressure tank now that temperatures have dipped down below zero. I've tried keeping a faucet running all the time to avoid freezing but it doesn't work even if I open it all the way. When it freezes, I have to go down to the crawlspace and turn on a space water in front of the tank for it to thaw. Any reason why keeping the water running all the time doesn't keep the tank from freezing? By the way, I also have a water filter and water softener, if that matters.
gcj
01-20-2005 10:25:48
 Re: Water Well in reply to gcj, 01-18-2005 11:25:05
I think keeping a light on 24/7 works fine with me. It"s cheaper and safer than a space heater. Thanks everyone for your help.
wilko
01-18-2005 23:26:35
kjm
01-18-2005 20:29:51
The little creek I drive across every day freezes up and I know it runs all the time.(Mississippi River) kjm
Glen25
01-18-2005 19:54:09
Mine will freeze off if I don"t keep a light in the well house, The place that always freezes is the small line going to the pressure switch. This keeps the pump from kicking on letting everything freeze. That"s where I would start. God luck
Jake 2
01-18-2005 18:58:58
I think before I ran the water all night, I might consider a heat tape on a thermostat and some insulation.
Hermit
01-18-2005 18:47:34
Since the pump cycles on and off based on tank pressure, I'm thinking that the water freezing starts in the line from the pump to the tank. That's where still water occurs even with the water running inside the house. Once the line on the inlet side of the tank freezes, then there's no water movement in the tank and it freezes. A water line heater on the inlet side and some good insulation should help.
old
01-18-2005 11:50:10
Sounds like you may not have enought insulation around the system. I never have problems with my system and its not well insulated but I keep a light on 24/7 in the well house it seems to be enough to keep it from freezeing
Rod in Smiths Falls, ON,
01-18-2005 18:04:53
 Re: Water Well in reply to old, 01-18-2005 11:50:10
Just be careful that the trickle of water out your sewer or to your septic tank doesn't cause it to freeze up. Then things can get really inconvenient.
I assume you have access to the electrical cord/heaters which you can wrap around water lines and plug in? They are thermostatically controlled, cheap and reliable in many applications. We even used one last winter to melt a hole through an ice dam on a roof.
