Tool Talk Discussion Forum
Heat in Basement Office
Steve-Maine
01-18-2005 02:35:06
I'm building an office in my basement about 12'x12' How many feet of fin baseboard heat should I need? It will have 2" walls with rigid insulation. Thanks
RWK in WI
01-18-2005 17:58:38
 Re: Heat in Basement Office in reply to Steve-Maine, 01-18-2005 02:35:06
It might be a good idea to have two seperate units on seperate thermostats. One to keep the heat at set temperature and the other to warm it up quickly when you want to use the office. It allows you to set the temperature low when you aren't using it as electric heat can be expensive.
Hydronic, John,PA
01-18-2005 05:37:41
I would use an electric (hydronic) baseboard heater system in the office. A five (5) FOOT SECTION should give more heat that you actually need. Pricey, though. HTH John,PA
