Tool Talk Discussion Forum
Clark propane forklift w/ Mitsubishi engine
throckmoron
01-17-2005 21:57:41
hello- I did a very stupid thing-- while changing my regulator I mixed up the fuel and coolant lines so I ended up w/ coolant in my cylinders-- I changeed the plugs which seemed to be fouled the way it was running, but it still is running very weak-- any advice would be very much appreciated--
Jon H
01-17-2005 22:33:13
 Re: Clark propane forklift w/ Mitsubishi engine in reply to throckmoron, 01-17-2005 21:57:41
Remove the large vapor hose that runs from the Vaporizer/regulator to the carb and drain any coolant out of the hose and regulator secondary stage. If the vapor outlet fitting is not on the bottom of the regulator,you may have to remove it from the mounting so you can angle it to get a complete drain. Hope you did not get enough coolant in the cylinders to hydraulic the engine. This can lead to bent rods,cracked pistons and other nasty stuff. Good luck,I hope your rig has no internal engine damage.Change the oil,as coolant in the oil is death to the bearings.
throckmoron
01-18-2005 07:09:58
 Re: Clark propane forklift w/ Mitsubishi engine in reply to Jon H, 01-17-2005 22:33:13
thanks for the response, I really hope not too
