Tool Talk Discussion Forum
Rolatape Measure
Big Dummy
01-17-2005 12:08:43
I purchased a measuring wheel at an estate auction. When I measured the circumference of the wheel it was 79.2 inch. Now I'm sure that there is a reason for that unusual amount but, I don't know what. Any ideas??
Dave Sherburne, NY
01-17-2005 16:54:54
 Re: Rolatape Measure in reply to Big Dummy, 01-17-2005 12:08:43
79.2" times 10 equals 792 inches which equals
66 ft. which equals 1 chain which is a surveyors
measure . 100 links in a chain. 792inches
divided by 100 equals 7.92 which is 1 link.
1 chain times 1 chain equals 1/10 th of an acre.
1chain times 10 chains equals 1 acre.
10 chains times ten chains equals 10 acres. I used to measure land in 1964 dragging a 66' long
steel tape every chain you put the tape thru a loop
on a steel pin and hoped you felt the slight tug
every 26steps so you could stop and put it thru a pin , and not have to start over. Before the steel tape it was actually pieces of wire bent
with loops on each end,7.92inches long, with one
hundred of them fastened together.
IHC Red
01-17-2005 22:00:07
 Re: Rolatape Measure in reply to Dave Sherburne, NY, 01-17-2005 16:54:54
Those were very useful facts with application. Thanks. It's interesting to know how they used to measure land. Understanding these "lengths" helps to clarify why properties are bounded and measured the way they are.
I once worked for a guy who had me use a wooden triangular "walking tool" (I don't remember what he called it). The tool "walked" from one point to another while holding onto the top handle and moving in a linear direction. It must have been either 6 1/2' or 79.2 inches from point to point.
His fields were a half mile long and he told me to count off x number of units (which would equal y acres) and work the field up to that point. How big was this tool from point to point and what was it called ?
Thanks.
Coloken
01-18-2005 06:02:07
 call an A in reply to IHC Red, 01-17-2005 22:00:07
"A"
Coloken
01-17-2005 12:31:13
Now my old memory is coming back.
Correct me is I am wrong.. Measure both directions, multiply together. point off 1/000 and you have acres. What we used to call a "government A"
Big Dummy
01-17-2005 12:58:50
 Re: Rolatape Measure in reply to Coloken, 01-17-2005 12:31:13
Thanks for your help it makes sense once you mentioned rod and acres.
I may actualy have purchased a pretty neat tool for .50 cents.
Thanks again for help!!
Dummy
Big Dummy
01-17-2005 12:54:16
After your clues I looked up some of the survey terms/measurements and 79.2 inches is 6.6'.
Surveying Measurements 1 yard = 3 ft = 0.9144 meter 1 rod, perch, or pole = 25 links = 16.5 ft 4 rods = 1 chain 1 chain = 4 rods = 66 ft = 100 links 10 chains = 1 furlong 1 link = 1/100 of surveyor's chain = 7.92 inches 25 links = 1 rod = 16.5 ft 100 links = 1 chain = 66 ft 1 furlong = 10 chains = 1/8 mile = 220 yards = 660 ft = 201.168 meters 8 furlongs = 1 mile 1 mile = 80 chains = 320 rods = 1,760 yards = 5,280 ft = 1,609.344 meters league = 3 statute miles = 4,828.032 meters
Units of Linear Measure 1 chain = 100 links = 66 feet 1 mile = 80 chains = 5,280 feet Units of Area 1 acre = 10 square chains = 43,560 square feet 1 square mile = 640 acres
Coloken
01-17-2005 12:22:02
Just guessing: 1 rod equals 16.5 feet 16.5 times 12 equals 198 inches 198 inches divided by 79.2 equals 2.5 turns per rod. (1 rod by 1/2 mile is 1 acre)
