Tool Talk Discussion Forum
HOOP BUILDINGS
Cowdude
01-16-2005 11:29:58
Has anybody tried one of these tarp looking covered quonset buildings? Would one of these be good for round bale storage? Thanks Sam
Nolan
01-18-2005 10:16:10
 Re: HOOP BUILDINGS in reply to Cowdude, 01-16-2005 11:29:58
I've made them and used them for years. Here's a few lessons I've learned over the years with them.
Don't use tarps. Use plastic film. Plastic film lets snow slide off, a tarp holds the snow on. The weight of the snow will make it collapse.
Plastic films you buy at Home Depot and such degrade to nothing in a year or two. You'll get more if you use the expensive good greenhouse plastic. Black plastic films last longer then the milky white ones do.
PVC works well, but after a few years it becomes brittle and will no longer flex and buckle if overloaded, but will crack and splinter. Using black plastic skins probably would prevent this.
I've used 20' lengths of 1.25" pvc on hoops 12' wide. That's about the limit you can get that has a chance at standing up to snow loads.
Next time I wouldn't use 20' hoops, it creates a large level area on the top of the rounded roof. I'd use 10' and a 90 or 45 degree elbow to make the roof peak.
I've done this a number of times over the years. Each time was cheap, but I had to do it many times. My in-laws have a metal piped greenhouse with commercial plastic over it. It's been there for something like 8 years now, without maintenance. I think they passed me on cost effectiveness a few years back. Especially if you consider your time and effort worth something.
riverbend
01-17-2005 08:51:52
UofM put up a couple for hogs at Lamberton, they are big and seem to work fine. I have a couple of smaller greenhouses that have stood up to 70+ mph winds. If you get much snow, the top needs to be a little peaked rather than flat, like a half circle would be. Line them up with the end pointing into the wind (east-west around here). The endwall bracing needs to be taken all the way to the ground and attached to something solid.
Johnbob
01-16-2005 13:35:09
We have several here in the county.Several of them are laying down from the snow that we had over Christmas.I don't believe I would want one.
