Tool Talk Discussion Forum
Welder Question
kraigwy
01-13-2005 15:35:40
Neighbor gave me a Lincln LN 25 welder, I don't know anything about it execpt have heard its a pretty good welder. Question is there is no power cord. No place to plug one in that I can find, Anybody know anything about this welder, If I could figure out how to get power to it I might be able to play with it enough to figure our how to use it.
Greg S
01-14-2005 13:22:58
 Re: Welder Question in reply to kraigwy, 01-13-2005 15:35:40
Pile Buck is right, this is a wire feeder only. Usually used on DC constant voltage welders but will work on a DC stick machine. Hook up one lead to the suitcase and power to run the wire feed motor, only thing is that the wire will always be "hot" so have to take care when you put it down that wire doesn't touch the piece you're welding on. Never tried one on an AC machine, the wire electrodes used in these units generally aren't compatible with AC welders.
Pile Buck
01-14-2005 14:11:26
 Re: Welder Question in reply to Greg S, 01-14-2005 13:22:58
Hi Greg, you know I don�t know if the LN-25 would work on AC or not. My first thought is no! But you can have a contactor kit installed in these wire feeders that way the wire is only hot when the trigger is pulled. You can also have a gas solenoid kit installed to have inert gas coverage. I have run aluminum with an LN-25 on a CV power source before. Only trouble I have every had with an LN-25 is I had to take a welding test, because the welding inspector on site felt my certifications were to old. My company arranged for a testing facility for me to take the test at, but they asked that I bring one of our wire feeds. So I took one of our LN-25�s a roll of wire and my welding gear. When I got to the facility, which was a production welding shop also. The only welding machine that was not being used was a Miller Gold Star 330 A / BP. I know the number because since then I bought the same machine. Anyway, I was just getting going on the test, and the LN-25 quite working. So I had to run back to the job site to get another one. Once I returned and started running the test, this LN-25 died. Back again to the job site for yet another LN-25. Once I retuned to the testing facility, the shop foreman informed me he had called the welding supply to see if they had any ideas what was going on with all these LN-25 wire feeds breaking down. They informed him that the Miller Gold Star was a single-phase machine, and the LN-25 needs to be run on a 3-phase power source. The shop foreman arrange for me to switch machines with someone else taking a stick test. After the LN-25s went to the shop for repair, we were told just the contactor kits needed to be replaced. But when contactor kits burnt out it blew an internal fuse. Lesson learned.
Greg Ne OR
01-14-2005 23:47:13
 Re: Welder Question in reply to Pile Buck, 01-14-2005 14:11:26
Hi Guys
These suitcase style wire feeders are set up for DC & have a DC motor to power the feed rolls I sure wouldn't want you hooking mine up to AC power source to try it. [>;
"the shop foreman informed me he had called the welding supply to see if they had any ideas what was going on with all these LN-25 wire feeds breaking down. They informed him that the Miller Gold Star was a single-phase machine, and the LN-25 needs to be run on a 3-phase power source."
The LN-25 shouldn't care if it is single or three phase power entering the power source as it gets its power from the output side.
A quote from the Operating Manual IM359-G. For use with machines having Code Number 10231,10232, 10233.
" POWER SOURCE CONNECTION
The LN-25 can be used with any DC welding power source. A constant voltage power source is recommended; however, the LN-25 can also be used with a constant current power source as long as the open circuit voltage is less than 110V DC. "
" CAUTION
Do not use LN-25 models below Code 9200 with any TIG or Square Wave welding power sources. Do not use LN-25 models equipped with internal contactors with non-Lincoln TIG or Square Wave welding power sources. Damage to the LN-25 circuit can occur as a result of the high output inductance typically associated with these power sources. TIG high frequency power should never be applied to the LN-25. "
The Rated Current without contactor is 500 Amps 60% Duty Cycle, w/Contactor is 300 Amps 60% Duty Cycle.
Kraigwy, I hope this is enough of a heads-up to get the Code Number off of your machine & contact Lincoln for an Operating Manual, with the troubleshooting & other it can save a lot of heartburn.
Pile Buck
01-15-2005 03:56:49
 Re: Welder Question in reply to Greg Ne OR, 01-14-2005 23:47:13
Hi Greg My one bad experience with the LN-25s was about 14 to 15 years ago, so not everything is real clear in the old memory! But after reading your post, right here is the problem, the Miller machine I was using is a Tig machine.
�Do not use LN-25 models below Code 9200 with any TIG or Square Wave welding power sources. Do not use LN-25 models equipped with internal contactors with non-Lincoln TIG or Square Wave welding power sources. Damage to the LN-25 circuit can occur as a result of the high output inductance typically associated with these power sources�.
Wonder way the major brands play these little games, where one won�t work with the other? Just to make it harder on the consumer? Thank you for your post I learned something here.
Pile Buck
01-13-2005 16:51:07
Hi kraigwy, I ran those LN-25 for years. It is not the power source, it is just a wire feed. One of the best field wire feeders ever made. They will run good on a cc machine, but as always it is better on a cv machine.
