Tool Talk Discussion Forum
Welding around electronic ignitions.
MLP
01-12-2005 12:56:15
This is not tractor related but could apply to newer tractors as well.
A friend of mine has a newer motorcycle with all of the modern electronics on it. He needs to have a muffler bracket welded back on to the frame. Is it safe to do so with out disconnecting every thing such as CDI and etc? I have not seen the bike yet but he tells me it is a major job just to get the battery out of this bike.
Thanks for any information.
Fred Kobs
01-13-2005 00:07:23
 Re: Welding around electronic ignitions. in reply to MLP, 01-12-2005 12:56:15
All the responses are good advice, I just wanted to add not only to ground as close to the repair as possible but also to get a GOOD ground. The cleaner the better. Fred
RustyFarmall
01-12-2005 16:28:10
It may be a real hassle to disconnect all the electronics but it will also be very expensive to replace all that stuff after you fry it. Disconnect everything you can.
Weirsdale George
01-12-2005 14:19:05
A few years ago, I welded on a truck (Dodge, I think it was) and the shop manual said to disconnect the battery and to disconnect and remove the computer module.
Any time you are welding, you are setting up a strong fluctuating electromagnetic field which could induce voltge spikes in nearby wiring.
kraigWy
01-12-2005 13:26:30
Anytime you weld on a vehicle of any type you should disconnect the battery. Wouldn't hurt hurt to disconnect the electronic ignition either. When disconnecting the battery disconnect the ground. This goes for any work on the elect. system also.
9NJoe
01-12-2005 13:17:23
MLP,
you have to look at where the current is going to flow. Ground the frame right near the weld. Dont ground it far away from the weld or the current will have to travel father along the frame to get back into the welder. You run into problems when the ground is placed such that the current is crossing gaps in the frame. Make sure you have a good ground right near the weld area and you should be OK.
Joe
HarryG
01-12-2005 15:19:48
 Re: Welding around electronic ignitions. in reply to 9NJoe, 01-12-2005 13:17:23
ANY EQUIPMENT, tractor, truck, car etc..... ..Best practice is ALWAYS disconnect battery and keep ground strap as close to area being welded as possible. I've heard of computers,alternators, radio's burned out. I was working in the truck shop, another mechanic was welding a fifth wheel support, he had ground clamp on spring saddle.. Went to move truck out,,,,, ,truck wouldn't move. Bad ground caused wheel bearings to weld to spindle and races. Don't ask why but it happens!!!!! !!! so be safe!!!!! !!!!! !!!!Disconnect battery
MLP
01-13-2005 03:21:11
 Re: Welding around electronic ignitions. in reply to HarryG, 01-12-2005 15:19:48
Thanks for the input guys.
Every one is saying what I figured. So I will have him strip it down. I have seen the effects of a ground being too far from the weld and parts welding together that were not intended to be. I know that the electronics can get expensive I replaced the coils on my bike this summer for about $130 each.
