Homelite chain saw model 27av. (Dies out when given throttle)
Red
12-09-2000 23:08:36
This chain saw is only 2 years old and has not been used very much in that time, maybe 3 or 4 days a year for the 2 years. The saw ran great all day and then just started to dog when giving it throttle. It dies right out if I do not let up on the throttle.I took the carb off and apart it looks just fine not much dirt and the diaphram looks ok. The book says to turn the low needle counter clockwise 1/16 turn if engine startes but will not accelerate. the problem is that it has these plastic limiter caps on the screws and the screw is all the way counter clockwise already. Its getting cold here in green bay I need to get this wood cut. Any ideas? can these caps just be taken off or repositioned?
John Green
06-19-2004 17:11:29
 Re: Homelite chain saw model 27av. (Dies out when in reply to Red, 12-09-2000 23:08:36
I don't know if it relevant but I have a 3-yr old Homelite 3314, which didn't cut very well. I put an Oregon chain on, and the cut really improved--flakes instead of sawdust.
But then the saw started to lose power, wouldn't rev fully up. Using a tip I go online, I took out the spark arrestor. Now it starts easily, and runs full power. Now I can go through an 8-inch log in 15 seconds.
There's an exploded view of getting at the spark arrester in the directions that come with the saw. But it's a little tricky reassembling the works after you do it.
Also, w/o a spark arrester, make sure you start the saw outside, and not near any fumes.
Norm
06-07-2002 05:42:14
 Re: Homelite chain saw model 27av. (Dies out when given throttle) in reply to Red, 12-09-2000 23:08:36
I have a similar problem with both my Homelite weed eater and my Homelite leaf blower. They are both less than a year old but they will "bog down" when they get hot and the engine dies. At this point it will refuse to start unless I let it cool for a half an hour and then its good to go for 15 minutes, when the cycle repeats itself.
Nobul
12-11-2000 15:48:44
Might also check the muffler.Had a weed whipper that plugged the muffler with oil and just couldn't breathe. Going to 50:1 instead of book rec 25:1 solved the problem and ran better too.
John in MA
12-10-2000 20:42:41
I don't have a recent Homelite chainsaw, but I have a Homelite backpack blower and a weed trimmer. They both have the limiter caps and springs. Just pull the cap off, adjust the saw, then put the cap back on at midpoint. Adjust the idle screw to the saw goes the fastest at idle, then back off just slightly. You may need to lower the idle speed screw after doing this.
Next time you have carb apart, take all rubber/plastic off and soak the metal body in carb cleaner. Then install the rebuild kit instead of using the old parts. I did that to an old Allis saw that runs fine now. Hard diaphram was the problem.
Al
06-07-2002 03:54:03
 Re: Re: Homelite chain saw model 27av. (Dies out when given throttle) in reply to John in MA, 12-10-2000 20:42:41
looking for repair manuel Mcculloth chain saw
mac cat,mod60016002 ser 171964 just runs no
power, thanks for any help
M.R.
12-10-2000 07:27:32
"Can pro users just remove the plastic limitier caps and run it that way? The answer is, no. It should be noted that the carburetor will not stay adjusted without the stops in place. Adjustment needles on EPA carburetors no longer have springs to hold them in place. The plastic caps function as the stops, so before you get the idea to remove the stops and run it this way, beware."
The above is a quote from Madsens web site. EPA pro saws are saws that are approved by Environmental Protection Agency (EPA).
Not sure if this applies to your particular saw, but you might want to check before removing the plastic caps.
You might try using a higher octane fuel. We find that our saws will idle and perform much better. Also make sure the mix you are using is fresh. It is usually recommend mixing only what you can use within six weeks.
AD
12-10-2000 04:59:26
Might check the fuel filter in the tank to see if it is clear and just to be sure take it out and use air to blow back through it,also while saw is running change setting on needle valves could be some trash in the port. AD
Peter Coffie
01-13-2002 16:17:53
 Re: Re: Homelite chain saw model 27av. (Dies out when given throttle) in reply to AD, 12-10-2000 04:59:26
Also check that the hose from the filter to the carb isn't collapsing (they tend to get limp from old age and collapse when the carb draws more juice when going to full throttle)
TonyR
03-06-2004 20:29:35
 Re: Re: Re: Homelite chain saw model 27av. (Dies o in reply to Peter Coffie, 01-13-2002 16:17:53
I have a Homelite that would run great one day and I couldn't start it the next . Sometimes it would be running good and then it wouldn't rev up like it should . I adjusted the carb , changed the filter , checked for a block spark arrester , loose carb , blocked air filter . The problem was a very small rub in the fuel line ar the carb fitting , This fitting and fuel line is too close to the body of the saw . THE RUB IN THE LINE WAS VERY SMALL.
