Tool Talk Discussion Forum
Replacing muffler on Allis Chalmers D17 Series IV
Jon Wolter
01-11-2005 06:38:08
My muffler fell of my D17 Series IV. Is there a separate pipe, that connects between the muffler and the manifold? If so, this pipe has rusted off, flush with the top of the manifold opening. I am assuming this is a threaded connection. What is the best way to try to remove the piece still in the manifold? I am afraid if I cannot get it out, I would have to replace the manifold also. If so, I am not looking forward to trying to remove old manifold bolts! Please help. Thanks!
GF in Indy
01-13-2005 10:30:09
 Re: Replacing muffler on Allis Chalmers D17 Series in reply to Jon Wolter, 01-11-2005 06:38:08
Yes, the top of the manifold is threaded.
play farmer
01-11-2005 10:17:38
Be careful, not sure on D series but the WD's and WD 45's did not have threads. They had a set screw that held them in place.
Fred Martin
01-11-2005 08:03:24
If you could heat the inner piece cherry red, you could drive a screwdriver or punch behind it and then probably pry it out...BUT...here is possibly a price to pay...all the heat going down and into the engine, but, the exhaust valves run red hot anyhow when the tractor is laboring...like pulling a breaking plow. If the broken piece is of a thickness such as a piece of water pipe...you might be able to weld something to it to wrench it out. Careful prying on the cast iron and don't break it...but it will stand more abuse when heated than with frost on it. Fred OH
