Tool Talk Discussion Forum
HOT WATER PRESSURE WASHER
BULLDOG
01-10-2005 14:23:50
HEY GUYS. I'M LOOKING TO PURCHASE AN ELECTRIC POWERED HOT WATER PRESSURE WASHER WITH ABOUT 2000 PSI TO CLEAN THESE OLD TRACTORS. WHAT RECOMMENDATIONS DO YOU HAVE FOR THESE? BE IT BRANDS OR BEST PLACE TO PURCHASE, ETC?
THANKS
buickanddeere
01-12-2005 11:34:49
 Re: HOT WATER PRESSURE WASHER in reply to BULLDOG, 01-10-2005 14:23:50
If the pump isn't a brass three piston Comet or better yet a CAT. It's a econo hobby unit with a very short service lift. Walk right on past. With a good pump you can feed it direct off the domestic hot water service and not have to mess and pay for the portable boiler. Even better with a water softener and a soap injector. A gas unit will give more cleaning power per $$$ spent. Go with 3000+ to 4500 psi or forever wish you had more grease and dirt cutting power. A 4500psi gas unit with soap addition and a Comet or CAT pump costs much less than a 2000psi electric with an attached boiler. And still have money left over if you upgrade your home/shop hot water heater and add a water softener.
NC Wayne
01-10-2005 19:52:49
I know there are several different brands out there but in my experience nothing beats a Hotsy. As for buying it we called the local distrubitor nd they brought it out, gave a demonstration and let us use it, and we made a decision from there. We've had one for 3 years now and haven't had any problems at all out of it. We've even ran it in the field using a generator and fed it through a filter with the water truck at a mine site where we were working and it performed flawlessly. Like I said in my opinion you can't beat a Hotsy.
Big Jim
01-10-2005 19:49:41
Northern Tool is a good place to start looking. They have a pretty good selection of pressure washers and accessories.
