Tool Talk Discussion Forum
die grinder?
jonathan small
01-09-2005 15:32:10
ok, im looking forwoard to restoring an old forage chopper and one of my brothers told me that a right angle die grinder would be best for small rust and cutting tin, but the other brother said it would be a pain in the xxx to use a die grinder. if anyone could tell me if a die grinder is a good tool for the job or not it would help me get this project going.
Rod (NH)
01-09-2005 17:06:04
 Re: die grinder? in reply to jonathan small, 01-09-2005 15:32:10
Hi Jonathan,
Yes, a die grinder will work for cutting sheet stock. You will need to get an arbor and some 1/16 inch thick abrasive cutoff wheels to suit the arbor. The wheels are usually 3 or 4 inches in diameter with mounting holes typically 1/4 or 3/8 inch in diameter, again depending on the arbor. Not as good or as fast as a plasma cutter but will get the job done. Not good for short radius cuts however.
third party image Rod
jonathan small
01-10-2005 16:11:15
 Re: die grinder? thanks but would like more info f in reply to Rod (NH), 01-09-2005 17:06:04
thanks for the info rod (nh) for helping me about chosing diegrinder but i want more info to make sure it wont fail thanks alot jonathan small
