Tool Talk Discussion Forum
sds hammer drill
MPK
01-09-2005 12:52:22
I am thinking about getting a sds hammer drill. Does anyone know the difference between sds and sds plus. I see some will take the sds plus bits.They also have sds Max which is a much bigger machine. I can see the max has a much thicker shank. Just wondering about the difference between the sds and the sds plus.
MPK
Big Jim
01-10-2005 00:47:16
 Re: sds hammer drill in reply to MPK, 01-09-2005 12:52:22
SDS Plus bits will work in an SDS drill, the other way won't. The SDS Plus has two additional slots cut in the bit to provide an additional surface to rotate the bit. The chuck has corresponding tangs so the old style bit will not fit. If you forsee a lot of use, the Plus should make bits last a while longer but you lock yourself out of buying old, cheap bits.
MPK
01-10-2005 20:17:55
 Re: sds hammer drill in reply to Big Jim, 01-10-2005 00:47:16
BIG JIM
Thank you very much for the info.Now I understand.You have been very helpful. Thanks again.
MPK
