Tool Talk Discussion Forum
Thrust Washer Material
Joe (IN)
01-07-2005 19:25:06
I've got yet another ridiculous situation to overcome to get this stupid tractor back together. I'm trying to reassemble a gearbox. The gearbox case is machined from mild steel and has a 1/8" or so counterbore on the inside where the input drive gear enters it. There was supposed to be a hardened steel thrust washer in that counterbore between the hardened gear and the case and then there is a snap ring on the outside to hold the gear in place. My thrust washer is AWOL and I've gotta make a new one. Not much hope of being able to find the correct one as every piece of this thing is obsolete. Is there a suitable alternative material? Brass or bronze maybe? If it matters, this area is splash lubed with gear oil and the maximun gear speed is appox. 1100 RPM. I've got a lathe, just don't know what the best material to make it out of would be, although hardened steel is not really an option. This is NOT real easy to get to should it wear out. I see brass thrust washers in transmission all the time, but was thinking bronze might be more durable. Advice?
Fred Martin
01-11-2005 11:03:12
 Re: Thrust Washer Material in reply to Joe (IN), 01-07-2005 19:25:06
Well, I read all the replies and guess I'm gonna make a few commments. Bearing bronze (not brass) is very, very hard and has a low coefficient of friction...in other words, slicker than snot, thats why it's used as a thrust material. If I were to use drill rod, the cheaper stuff is designated as W-1 and it is water hardening...from dull to medium cherry red and quench in water...and I would NOT draw it one bit. Leave it as hard as it gets! What is a few more points on the Rockwell scale gonna hurt? It wouldn't hurt if it was 65C scale! It's a wear surface! Tool steel you could quench in 10 or 20 wt. motor oil...cause I just know you don't have heat treating oil handy. I make stuff like this and this is my approach and you don't have to be a metalurgist, just read a book on the subject and do it! Fred OH
Bob - MI
01-09-2005 08:34:49
Steel OEM part suggests that there is quite a load and the mating part is taking some of the wear. My suspicion would be that Bronze/Brass would be too soft. You may get a suitable replacement from a bearing house but you could probably machine one yourself from tool steel in the annealed condition. Drill rod or probably H-13 would do a good job. Drill rod has the advantage as you can harden it yourself with a torch. Heat it very gradually to a straw color and let it air cool.
This kind of thing has helped me in the past. Good luck
MAC,IL
01-08-2005 11:30:55
Thrust washers of a variety are pretty easy to obtain. Check with a local bearing distributor.
Davis In SC
01-08-2005 10:49:39
I bet a bearing house has or can get a hard steel thrust washer. Many thrust bearings run against a flat washer, they are hardened like bearings are. You might have to buy the bearing assembly to get the washer, but still cheaper than having to make something.
Vern-MI
01-08-2005 09:23:05
How thick is the washer supposed to be? The counter bore is 1/8 inch deep. What is the thickness of the old washer?
Try a transmission rebuild shop to see if they have a replacement hardened steel washer of approximate size or one which is large enough to machine a suitable washer. Even automatic transmissions use hardened steel washers against soft cases and related parts to provide a suitable wear surface.
If there isn't any other choice then use SAE 4140, or red dot, or tool steel of the approximate thickness and then heat treat and draw to Rc 45-50. Surface grind the washer afterwards to make it flat.
Like you said, it is too difficult to tear back into to later fix a failed jury rigged setup.
dr.sportster
01-08-2005 08:53:30
thrust washers on the sides of motorcycles con rods appeared bronze after some wear you could see steel underneath as if the bronze was electroplated onto the steel washer.Years later the same part became all steel without the bronze plating.these all steel ones were harder than the bronze plated washers and wore out less because there was no bronze platingto give off to any friction.POInnt being a steel one might be better.My opnion is brass is too soft .Im not a metallurgist just suggesting steel.
Dieselrider
01-08-2005 05:16:01
Since I haven't seen the application myself, I am guessing at the exact use here. You can probably use aluminum bronze or better known as "wear bronze" as a washer. It's pretty tough stuff and you should be able to get it from most suppliers like Mcmaster carr and MSC. It's not too bad to work with. If in a situation where something is going to be turning against it all the time, you may want to use a "tool" steel and heat treat with a torch to cherry red then "quench" in oil or find a local machine shop that does heat treating that would throw it in with their jobs for heat treat and "draw" cycle.
Joe (IN)
01-08-2005 08:08:48
 Re: Thrust Washer Material in reply to Dieselrider, 01-08-2005 05:16:01
There's really no "thrust" per se on it. It's a straight cut gear. When everything is assembled, it is splined to a shaft and won't be moving around much other than rotating. I think the purpose of the washer is to keep the hardened gear from riding against the mild steel housing more than anything else. It's more of a spacer.
Ol Chief
01-07-2005 19:46:21
I have been around lots of heavy duty machinery and have always found bronze to be the metal of choice.If you have seen brass thrust washers they were possibly the metal of convenience.Are you sure that the washer in question is not just a spacer. Maybe you can figure where the load is really coming from and decide if thrust or spacer.
MetalZ
01-08-2005 16:38:05
 Re: Thrust Washer Material in reply to Ol Chief, 01-07-2005 19:46:21
Hello Joe
Tell us what you are working on, and what/where the part is. Someone may have an exploded view to assist with material specs.
Good luck
MetalZ
