Tool Talk Discussion Forum
Homelite Super XLAO Loves chain oil
Lee Anfinson
01-06-2005 19:20:46
I have two Homelite Super XLAO saws and they both go through the chain oil. Is there a way to control the oil flow to the bar?
JT
01-07-2005 15:16:14
 Re: Homelite Super XLAO Loves chain oil in reply to Lee Anfinson, 01-06-2005 19:20:46
Why compain. I complain if mine does not use enough oil. If you use less oil, then you will have premature bar and chain wear. A $4.00 gallon of bar oil id the best insurance you can get. It also cools the chain, so you do not get the chain stretch. You do not really want to use used motor oil. Not enough takc to hold it to the bar and chain and used oil is full of dirt from the engine, just like using sandpaper on the bar and chain. I knwo people use it and have not trouble, but not a good idea.
TomTX
01-07-2005 06:47:40
Lee, you said you were using used hudrolic oil in the saws. That is probably your problem. Bar chain oil is much thicker and much stickier than hydrolic oil. At the current prices for chain, bars, and repair labor, using proper bar oil is the cheapest money you could spend.
Kevin (FL)
01-07-2005 05:18:58
Lee,
We cut alot of wood with the XL12's & the SXLAO's. As far as I'm concerned there's no such thing as using too much oil on the bar. This is what protects the bar & chain from heat and wear. The problem with those saws is that the oil tank is too small and must be refilled regularly. It seems I refill ours after about 10 or 15 minutes of solid cutting. I don't let it run dry or sparks will fly off the bar. If you're using (and buying) bar oil, consider using crankcase oil, expecially from diesels--that's what we do. Haven't bought bar oil in 20+ years. Our chains "stretch" sooner than they wear out and we've only replaced one bar when a tree fell on it and bent it beyond repair. Our two bow saws were bought in 1978 and are still running with the original bows.
Lee Anfinson
01-07-2005 05:39:36
 Re: Homelite Super XLAO Loves chain oil in reply to Kevin (FL), 01-07-2005 05:18:58
Kevin I use hydralic oil from when I service my tractors, so I never buy bar oil. One saw uses oil at the same rate as yours and the newer one uses a bit more. That"s what makes me think that there may be an adjustment somewhere. Thanks for the reply! :-)
RustyFarmall
01-07-2005 03:53:37
I think there should be an adjustment screw to control how much oil is being pumped out. I am not real familiar with the homelite saws but somewhere on it should be 3 adjustment screws, 2 of these will be for the carburetor, the third screw will be for the chain lube.
