Tool Talk Discussion Forum
Welding Hardened Steel
Joe (IN)
01-06-2005 05:46:38
I'm working on a tractor with a rare auxilliary transmission. One of the original parts of the installation kit was a longer PTO shifter coupler to compensate for the 1 1/4" added tractor chassis length. Somebody has mowed with the PTO not fully engaged at some point and chewed the splines up in the end of this rare part and since the machine is apart for a tranny overhaul, I'm trying to fix it. I've got a new stock length coupler, but it is far too short. I can't find another stock part that is long enough and I've pretty well run out of options. It's looking like the best solution is to cut a section off the rear of the damaged coupling and weld it to the back of the new one to get the proper length and sufficient spline mesh with the PTO shaft. But these parts are hardened. I had the hardness checked at work and they are 55-57 Rockwell. I've been researching the correct welding procedure on the net, but it varies by steel type. Anybody got any clue what kind of steel this is and roughly how to properly cut and weld it so as not to compromise its torsional strength? It looks like it will have to be annealed, preheated, welded, and then heat treated again. I can have all this done here at work, but I gotta know what procedure to tell these guys to use. Help? Suggestions? Sorry for the long post.
lucass
01-07-2005 06:40:08
 Re: Welding Hardened Steel in reply to Joe (IN), 01-06-2005 05:46:38
i would preheat to 200 and weld with a 7018 rod. lucas
buicknaddeere
01-06-2005 20:06:26
There is a shop that has advertised in Green magazine that rebuilds splines. Straight,tapered don't matter.
dr.sportster
01-07-2005 07:14:56
 Re: Welding Hardened Steel in reply to buicknaddeere, 01-06-2005 20:06:26
Best answer,best answer, problem solved,done by pros,shaft strong as new.[unless it costs a ridiculus price]I say Buick has nailed it.
sphargy42
01-06-2005 14:52:40
What horsepower equipment are we talking about ? What tractor model ? diameter of shaft ? wall thickness of coupler ? how far is the damage on the splines in the coupler ?
Joe (IN)
01-06-2005 22:44:12
 Re: Welding Hardened Steel in reply to sphargy42, 01-06-2005 14:52:40
The tractor is a Ford 600, so about 30 HP or so. The drive end splines are about 1 3/8" and the driven shaft is 1 1/8". The coupler is about 2 1/4" diameter, but has a deep groove cut in it for the shifter fork. The spline damage is on the drive end. The drive end splines are only 3/8" long and the first 1/4" is chewed up.
T_Bone
01-06-2005 12:29:25
Hi Joe,
Comenting on welding rotating parts is the same as comenting on welding fuel tanks, too which I do neither because of the high safety factor.
I personaly would look at rebuilding the splines.
A posibility of using two new couplers (if needed) with a short piece of new shaft connecting the two couplers ?
If welding would be required on the new couplers then both would contain approx the same steel qualitys.
Remember a rotating mass has to be in balance or all heII will break loose very shotly.
T_Bone
Jet9N
01-06-2005 12:22:03
Does the shaft need to be longer for any other reason than to gain spline engagement? If that is the only factor would it be possible to make a new bearing/seal carrier/flange/housing that would reposition the whole assembly further forward? Just a wild thought.
Jet
ScottP
01-06-2005 09:41:33
Joe
I would bevele the edges to 30 degrees. Then slide both pieces on the old shaft to make sure the splines are lined up then weld. Then grind down the weld flush with the base material. Have a slevee machined that will press fit over the entire coupler and then weld in place. Have the new rebuildt and machined to fit coupler heat treated.
Scott
Davis In SC
01-06-2005 09:31:35
I would guess that the part is induction hardened, giving it a hard surface, & a tougher inner core. If you weld it, it may break next to the welded area. If you do a post-weld draw to reduce stress, you risk softening part to the point wear will be a problem.
Jim@concordfarms
01-06-2005 08:36:54
Welp, if nobody else is going to say anything, I'll throw my 2 cents in.
I think the first thing I'd do is tell us exactly what you're working on. You'd be surprised some of the stuff people have found thru this site. Your part might not be as obscure or obsolete as you think.
I think just as important as your welding method is how are you going to keep it straight? Welding a shaft with splines is going to be difficult to keep straight. I used to tig hardened steel in plastic molds(New Die 5). Never preheated it, just welded fairly thin layers. But, what you have may behave differently. Maybe T-bone will pop up. He's the pro. Jim.
dr.sportster
01-06-2005 08:34:46
I cant imagine it to have enough strength when you are done.Wouldnt it be better to have a machinist make you a new shaft.A welded shaft needed good torsional strenth is not normal practice.Although some load would be taken by the driven end I would thing the end would snap off on the first usage.Not claiming to be an expert but have you heard of this being done before?You could have it heat treated yourself.[the machined one that is.]
danielgillespeiq
01-06-2005 16:38:11
 Re: Welding Hardened Steel in reply to dr.sportster, 01-06-2005 08:34:46
What you need to do is grind a V bevel into booth pieces 1/2 wide 1/4 deep which is called a V bevel. Then heat it up to 1100 to 1200 with torch booth pieces ant tack it together alligning everything. Then use a 6011 stringer bead which has alot of heat to burn into the metal. Take a grinder and grinf the weld down smooth so no bubble or pockets are visible. The stringer bead should not complete the weld it is just to burn through to give penetration. B/F you grind leave the slag on there tell it completly cools down( heat disaptionis the key) then grind. Use a 7018 to complete the rest of the weld making sure you let it cool the grind it pretty much back down so no bubble or pits are visible because this causes weak points. Once the welds is done heat to around 500 degrees and find some way to control the heat like wrpping with a fireproof blanket tell it complete cools. DO NOT DO NOT cool down with water at all b/c this will cause major crack and stress problems!! Hope it helps and good luck
