Tool Talk Discussion Forum
Sears saw--counter rotating blades and sheet metal
Neal
01-05-2005 16:43:15
Has anyone used the new Sears saw with the two carbide blades that turn in opposite directions for cutting sheet metal? I got one for Christmas and I'm thinking this just might be the "thing" for cutting steel siding. I need to build another leanto for my wife's horses. The last one I built, I used tin snips to cut the metal. The blades for this saw are not cheap.
Kendall
01-12-2005 05:54:00
 Re: Sears saw--counter rotating blades and sheet m in reply to Neal, 01-05-2005 16:43:15
My Dad used to sell vinyl,aluminun,steel siding and all the worker bees on the job used plywood blades turned backwards in their circular saw.
Gerald J.
01-05-2005 20:15:21
A couple months ago I was replacing rotted wall girts on my machine shed. I tried to cut them with my saw with a B&D Pyrhana blade. Each time I touched the tin, I had a slot.
I'd say keep the blade exposure to a minimum, wear safety glasses and a full face mask, and leather gloves and get on with it.
The crew that built my new shed last winter used a power shear attachment for a drill that cut a narrow strip out.
Gerald J.
Lincoln
01-05-2005 19:12:00
I have had good luck cutting steel siding with a regular circular saw with the blade in backwards.
old blue
01-05-2005 19:33:24
 Re: Sears saw--counter rotating blades and sheet m in reply to Lincoln, 01-05-2005 19:12:00
If you dont get a result that you like with that try one of those abbrsive disks that the hardware store has. if all else fails. I know the carpenter that installed a couple windows for us just used hsi circular saw as it was ( blade in the correct way) and went to town, now granted that was aluminum siding but hey try it with an old blade and see what happens.
