Tool Talk Discussion Forum
hydraulic tank
ruscom redneck
01-05-2005 15:43:57
I have aquired an old "homemade" gas powered logsplitter that I would like to do some work on before really using it.The unit has a hydraulic tank & spin on filter. I am going to install a fresh filter, but not knowing what kind of fluid is in the hydraulic tank or how long it has been there,I would like to clean/flush out the tank & start new.I'll then know the quality of the fluid & when it is due for changing again.My question is "How do I flush out an old tank & what do I flush it with or do I need to do this?" This splitter has been loaned out quite often from what I'm told & I just don't know what might have been mixed in there.Any suggestions are appreciated!! Thanks!
wdTom
01-05-2005 17:21:20
 Re: hydraulic tank in reply to ruscom redneck, 01-05-2005 15:43:57
Are you going to change the oil in the cylinder too? Put enough in the tank to cycle the cylinder out and then drain it again, will get rid of most of the old.
Midwest redneck
01-05-2005 17:05:48
My opinion is as follows. Is there just old oil only or sludge too. If there is sludge then you will need to scrape this out and clean it up. If only old oil then drain, clean with mineral spirits and wipe down, fill with new oil. It would be nice if the top of the tank came off, does it?. Also use a standard hydro oil.
ruscom redneck
01-06-2005 07:52:26
 Re: hydraulic tank in reply to Midwest redneck , 01-05-2005 17:05:48
HI! Nice to meet a fellow "redneck"!No the tank does't open up to ease cleaning.Just has the "fill" opening on top & supply opening at the bottom.(plus return line from valve) I guess I'll empty the tank & shine a light inside to see how bad it really is.Hopefully I can just add new fluid & filter . Thanks for the replies I received!
