Tool Talk Discussion Forum
wood chipper blade sharpener
RandyS
01-05-2005 13:25:49
Have a pto wood chipper and it"s time to sharpen the blades. Is this something I"m able to do on my lawn mower blade sharpener or do I need to buy a chipper blade sharpener? If I need to buy one do any of you know where to look for one? Thank you.
JT
01-06-2005 09:14:44
 Re: wood chipper blade sharpener in reply to RandyS, 01-05-2005 13:25:49
These blades are a very hard steel and need to be sharpened with something very fine, and not very fast. If you use a grinder, you can get too much heat and destroy the blade, plus the edge will be very ruff, and not cut clean, this put s a lot of additional strain on your power supply, I sharpen them either with a belt sander or a hand file. But, take time doing it to keep the edge cool, make sure you follow the angle already there, or you will make it worse than it is now.
thynes
01-05-2005 15:41:29
I sharpened the blade on my chipper and blades on my mower last summer with my belt sander. I got a much "cleaner" edge than with a grinder or hand file, and I was done in only a few minutes.
Don't let the metal get too hot or it will loose its temper.
Tim
hjp
01-05-2005 15:16:04
most blades including the ones on my DR are made of a much harder steel than a mild steel blade that are on lawn mowers.
I use a diamond file for mine unless you chip a blade it should take an edge with a couple of passes.
