Tool Talk Discussion Forum
metal cutting saws
Mark /ca
01-04-2005 10:07:37
Hi,
I would like to get a new & bigger horizontal bandsaw. I do a lot of meatal work and I'm tired of the little tiny one I have. Any ideas, good or bad brands?
RickL
01-06-2005 06:23:28
 Re: metal cutting saws in reply to Mark /ca, 01-04-2005 10:07:37
Mark; As I mention in earlier post I use a Ellis. If you are cutting alot of angle get the model that has swivel head you will never regret it. You swing the saw head to angle you need and cut. You never have to move the steel. The blades I use I can usually get over a years use out of them. They are 1" size in what is call vari-tooth. And I will only run one brand. I have been the discount,harbor freight etc route,those blades were junk. Let me know and I will tell you more info on how you can really get more life out of your blade by cutting steel in the right position. It does make a difference.
Ryan -WI
01-05-2005 06:41:57
I have heard good things about Ellis. The model that I have in my shop at school is a Grizzly 6x10 and it does the job fairly well, can be run dry or with coolant. Blade size is a bit quirky and cutting at an angle requires moving the saw and or the steel, but overall not a bad deal. It also has a table that can convert it to a small vertical saw.
Butcher
01-04-2005 14:21:54
Just got my new Grizzley catiloge today. They have some nice saws in it at good prices and cheap shipping. Most of there stuff is made in China but hey, what aint anymore?
RickL
01-04-2005 10:57:35
I run a Ellis brand and love it. It is a dry cut saw,can cut angles and other cuts also woth out moving the steel.
