Tool Talk Discussion Forum
Questions on Logan metal lathe
Far North
01-03-2005 13:11:03
I am thinking of buying my first metal lathe. It is a 12 x 28" with 1 HP motor, 8" - 3jaw chuck, tail stock, chip tray, and stand. The seller says it is in good condition. I would use for
small repair projects and making parts in my tractor restoration hobby. Seller is asking $1500.00 for the lathe. Is this fair price, is a Logan brand a good machine, and what things should I look at when I inspect the lathe? Thanks.
Davis In SC
01-04-2005 20:06:24
 Re: Questions on Logan metal lathe in reply to Far North, 01-03-2005 13:11:03
See if you/or seller can take a few test cuts under power. I have seen beautiful lathes that chattered, & clunkers that made mirror-smooth cuts....
dr.sportster
01-04-2005 19:49:16
Rereading what I posted the other dayI would like to add:Imay live in an area where more old machinery is available than you.If you like this one machine and you will use it and it has a chuck for the tailstock and a means to hold atool now so when you got it home you could turn a peice of metal without spending more money on tooling.In good condition [not pristine as I stated]1500 could be reasonable.Some wear just not all abused.
jakej
01-04-2005 09:09:41
The Logan lathe is one of the best, make sure that it has a quick change gear box, however missing tooling will add much more $. Logan now is located in Harvard IL, web site www.loganact.com
wdTom
01-05-2005 17:33:42
 Re: Questions on Logan metal lathe in reply to jakej, 01-04-2005 09:09:41
While I enjoy the QC gearbox on my12" Lodge and Shipley, I also get some satisfactio from making up the gear train on my 10" Logan. QC is nice but not mandatory if the lathe is in good condition.
eeleater
01-03-2005 18:11:15
The logan lathes were made in the USA. Go to the site below for more information. It may take a while to open due to the pictures. The site also sees much traffic- enough that they cannot open all of the site each day. The Logan site opened when I just tried it. If it does not open when you try it try the following day- or better yet go to www.lathes.co.uk/ and read about the ones you can open that day
www.lathes.co.uk/logan/index.html
J. T. L.
01-03-2005 14:46:32
Join up with this Yahoo Group. Anything you ever want to know about a Logan Lathe can be found out by asking these guys. I have an 11" logan and it uses a three quarter hp motor and it works great.
Link
John in Pa.
snitkawl
01-03-2005 14:45:58
Whether it is too much depends on condition as well as what you get with it. How about tooling? You can sink a lot of money in the tools and holders you need to use a lathe. Another thing to think about is the distance between centers. With a 12" swing, 28" between centers seems short. How big is the hole thru the spindle? With that short bed you will probably need to use it quite a bit, so the bigger the better. My lathe has a 3 9/16" hole and it is not big enough. If the lathe is as the seller says, has some tooling, and suits your needs(or wants)it sounds like a decent deal to me.
dr.sportster
01-03-2005 13:48:17
Seems like that should be about a 5 horsepower motor.Is it 3phase? With so many machine shops closing I think it sounds high priced.Unless its original owner of a real low mileage machine that comes with alot of tooling I would keep looking.What you want to avoid is one from a school they are beat up by students.1500 should get you a pristine condition lathe.Use ebay to compare prices.Look closely at the ways for wear etc.Just my opinion of course ,but too much unless it is like new.
dr.sportster
01-03-2005 14:10:07
 Re: Questions on Logan metal lathe in reply to dr.sportster, 01-03-2005 13:48:17
Open everything up if there are any broken teeth on any gears its probably from a trade school.Just lok at every surface where friction occured.Act like you Know what your lookin at.Take you time.For the same money you can get a smithy.This is a small machine aimed at hobby machinists.But it also does milling.It is Chinese more than likely but is checked for accuracy before they sell it.Bad ones are rejected.Quality should be ok.[That doesent sound too good "should be"]So shop around years ago our country actually manufactured things,when China took over that all the good machines stayed here for us to use.
