Tool Talk Discussion Forum
Which is the stronger joint?
Uncle Arnie
01-02-2005 18:50:11
I am going to make a hay fork for the front of my tractor and I was going to weld some pipe tp pipe and saddle the joint or weld the pipe to some square tubing the same size or bigger to put the spears into to pickup the bale. Which joint would be stronger? Thanks
T_Bone
01-03-2005 22:25:41
 Re: Which is the stronger joint? in reply to Uncle Arnie, 01-02-2005 18:50:11
Hi Arnie,
In that application, both joints would benefit from being plated between the spear and the cross member. The backing plate should extend 4 diameters of the spear on either side of the spear.
Example: if your spear diameter is 1-1/2" then your plating should extend 6" on either side of the spear.
A "A" shaped gusset would work well at the spear joint on both top and bottom.
To stiffen the joint futher you could plate the cross member.
30� is strongest of all angles with the least amount of material used.
Depending on the axle used, you might have to heat the weld zone to a dull red then let cool then weld if your having your welds crack.
T_Bone
ScottP
01-03-2005 11:40:58
The truck axle sounds like the cats meow. You could make a flange on the frame and the bolt the axle on. If it ever broke or got bent you could just bolt on a spare axle.
Scott
Hound
01-03-2005 05:38:45
...ditto on the truck axles. Never had one bend, thousands of bales later. Hound
old
01-02-2005 22:21:41
If I get what your saying and you want to use the pipe to stab the bale it will probably bend. Go to a truck repair shop and see if you can pick up an axle from a big rig. most of the time you can get them for scrap price and you will never bend it. I built one that way and ended up bending the frame not the speir
Ron in Nebr
01-02-2005 21:30:05
If I understand correctly that you want to weld something that sticks out at a 90deg angle to either square or round tubing, I"d have to say that the round tubing would resist twisting better than the square. I"m around alot of fabricated tubing racecar chassis and you can buy "em with the main framerails built out of either round or square tubing. Selling points for each are- Round tubing doesn"t flex(twist) as much. Square tubing flexes slightly more but easier to repair when you wreck them.
If you go with round, be sure to get a proper "fishmouth" on the peice you"re welding to it so you can get a complete weld, and also add the gussets like the other poster said.
Davis In SC
01-02-2005 20:09:03
Either one, as long as you add a gusset...Gussets are the only way to get any strength in 90 degree joints.
