Tool Talk Discussion Forum
Static electricity question
oliver power
01-01-2005 16:04:04
Just got a shop vac for christmas. After useing it in the basement(concrete floor) , should I touch the metal handle(attached to plastic), I would get a static electrical shock. And quite a shock at that. My question is: is the electric comming from me or the shop vac? Seams like if it was comming from me , I would get the shock no matter what I touched , grounding me in the basement. Now , the metal handle is bolted on to the vacuume with metal bolts , which go into the vacum reservor. Is the air inside the vacuum being charged as the vacuum runs? Am I the ground rod? Or is there something wrong with the shop vacuum. I thought about putting a small chain from the handle , letting it drag on the floor. What do you guys think? Thanks in advance
buickanddeere
01-02-2005 18:59:19
 Re: Static electricity question in reply to oliver power, 01-01-2005 16:04:04
If you want a unsupected blast of static. Try setting off a CO2 fire extingusher on a cold dry winter day. With one hand on the nozzle and the other on the handle. You will get whacked several times hard enough to almost drop the extingusher. A poke of 10,000V static ruins electronic equipment on the spot or after a few hours useage afterwards. The moving air is carrying electrons away so the source is getting more and more positive. ( electron flow not conventinional)
Missouri Boy
01-02-2005 11:41:55
This reminds me of an event which happened in a 1956 Mercury with new plastic seat covers. My sweetheart and another couple had been riding around in my old 1953 Pontiac with leather seats. My sweetheart who was wearing a nice short wool skirt invited me to get into her brothers Mercury to be alone for a moment. As my hand passed between her wool skirt and her silk slip the entire interior of the car lit up. I thought the wrath of God was upon us and the loving stopped forthe night. Had not thought of this for many years!
Leroy
01-02-2005 04:42:02
I don't agree with the static electricity, I would not use that vac again till checked out, I think something is wrong with it
bilko
01-01-2005 17:24:30
Oliver,
We have problems with hilo"s at work when you touch metal you get a shock. The way we take care of it is to attach a piece of rubber on the bottom of the hilo, so that it drags on the ground when you are moving. Then you dont get anymore shocks. Might work for your vac just a thought. Mike
Davis In SC
01-01-2005 17:11:06
I have a ShopVac that really generates static. It is caused by the air rushing in, same as walking on carpet. The Wand is metal, hose is plastic, so wand has no place to dissipate static to. I have learned to touch wand to handle of Vac, before touching the vac to move it, turn it off etc. At the plant, we have vacuum loaders that suck up plastic pellets into a hopper. Static was an issue , til we attached a grouding wire to the metal wand.
Dusty MI
01-01-2005 17:04:58
About 35 years ago when I was an apprentice electrican we were dry core drilling concrete with an electric hammer drill. It was my job to hold the vacuum hose to keep the dust down, the vac was all steel with a 3 wire cord grounding it. When the hole was done and I turned the vac off I would get that same shock you are getting. I soon learned to keep one hand on the vac thus draining the static charge instead of letting it build up and zapping me when shutting the vac down.
Dusty
tech4
01-01-2005 16:37:58
First of all congratulations on a dry basement. The dry air is the main player in this static shock situation. It is no different than the static shock after walking across carpet or sliding across the car or truck seat. The dry suction air through the plastic or rubber type tube will generate static electricity. The air itself is not charged but anything metal becomes charged. . Everything metal on the vacuum and you would have to be bonded together to prevent a static shock. I use a grounding strap connected to my wrist when working on computers to prevent a static charge from damaging the sensitive electronic chips.
You could try a small chain or static strip from the metal of vacuum to the floor or wear leather sole shoes instead of rubber or bond yourself to the metal part of the vacuum. A different brand vacuum may work better. Lots of trial and error to try different bonding solutions or of all the crazy things in a basement turn a humidifier on. Or wait till summer when the wet humid air will solve the problem.
Bob
01-01-2005 17:12:54
 Re: Static electricity question in reply to tech4, 01-01-2005 16:37:58
Last year, (I've been looking forward to saying that!) someone on the KL board was using a shop vac to suck up ground feed and was getting shocked by static. They were advised to wrap a bare ground wire around the plastic parts, from the nozzle, around the hose, to the machine, and ground it. I can't recall if they reported back as to whether they actually tried that or not.
There have been reports of vacuum explosions when vacuuming up various powders under dry, staticky conditions.
thurlow
01-01-2005 17:17:20
 Re: Static electricity question in reply to Bob, 01-01-2005 17:12:54
"staticky"????? Next, you'll be trying to tell me that ampacity is a word.....
RZ(WA)
01-01-2005 18:51:14
 Re: Static electricity question in reply to thurlow, 01-01-2005 17:17:20
Conductor ampacity
The smaller the wire, the greater the resistance for any given length, all other factors being equal. A wire with greater resistance will dissipate a greater amount of heat energy for any given amount of current, the power being equal to P=I2R.
Dissipated power in a resistance manifests itself in the form of heat, and excessive heat can be damaging to a wire (not to mention objects near the wire!), especially considering the fact that most wires are insulated with a plastic or rubber coating, which can melt and burn. Thin wires will, therefore, tolerate less current than thick wires, all other factors being equal. A conductor's current-carrying limit is known as its ampacity.
Primarily for reasons of safety, certain standards for electrical wiring have been established within the United States, and are specified in the National Electrical Code (NEC). Typical NEC wire ampacity tables will show allowable maximum currents for different sizes and applications of wire. Though the melting point of copper theoretically imposes a limit on wire ampacity, the materials commonly employed for insulating conductors melt at temperatures far below the melting point copper, and so practical ampacity ratings are based on the thermal limits of the insulation. Voltage dropped as a result of excessive wire resistance is also a factor in sizing conductors for their use in circuits,
So There !!! :)
Bob
01-01-2005 17:24:06
I covered my bases on that one!
I looked it up before I posted!
And, yes, I know all about ampacity, from the "Allen's Ampacity" thread, plus I worked a number of years for my Uncle, a Master Electrician, and I'm VERY familiar with the NEC's ampacity tables!
A+
01-01-2005 18:24:12
 Re: Static electricity question in reply to Bob, 01-01-2005 17:24:06
You Get an A+ for that one.
steveormary
01-01-2005 21:51:08
 Re: Static electricity question in reply to A+, 01-01-2005 18:24:12
And what does Allan know about ampacity.
He is probably trying to figure how to stuff 10# of taters in a 5# sack. Kinda like trying to carry 30 amp on a 20 amp wire.
Bob
01-01-2005 22:04:05
 Re: Static electricity question in reply to steveormary, 01-01-2005 21:51:08
Incase you missed it a while back...
