Chainsaw carb not pulling gas from tank
Bill
12-06-2000 14:17:28
I have an older Craftsman chainsaw. Have cleaned the carb with commerical carb cleaner (soaked it). Also have rebuilt carb, new screen, gaskets, diaphram, etc.. If I use a manual vacum pump I can pull gas from the tank. If I sray cleaner or starting fluid in the carb it will start, but still not pull gas from tank and dies. Pulled muffler and piston does not look scored. How do I check the vacum port on the engine that is used to activate the carb diaphram so that it pumps fuel? Any other ideas.
Thanks..
Bill
Douglas Murphy
01-20-2002 12:43:20
 Re: Chainsaw carb not pulling gas from tank in reply to Bill , 12-06-2000 14:17:28
I have a old sear chain saw run good I work on
it to git to run wold like to know how old it is
model no 917.60040 serial no 284658 it mark 46-G
my email is dbmurphy@[email protected] thank you
Bob M
12-07-2000 16:39:43
I encountered a similar problem on a weedwhacker last summer. Problem turned out to be a plugged fuel inlet screen inside the carb body. The screen is a cup-shaped affair, about the diameter of a pencil eraser. The mesh openings are so small it looks like a pressed-in sheet brass plug at first. When I tried to blow air thru it, found it was plugged up. Carb cleaner wouldn't touch it, but when I lightly heated it with a propane torch, it took only a moment for it to burn clean. Rinsed it in carb cleaner, put it all back together, and now it starts on a couple of pulls every time.
Rob
12-07-2000 09:02:07
Have you made sure your exhaust isn't plugged? I had a weed eater that wouldn't crank until I removed the exhaust - dirt dobbers had built a nest in it - completely filling it with dirt! Just a thought.
Rob
lgd
12-06-2000 18:24:20
put a dab of grease over the pulse hole with carb off, pull start rope if the grease blows off-- the port is clear. Also be sure you have holes matched in gaskets and flanges.
rod
12-06-2000 16:21:57
Have you pulled the filter out of the fuel tank? Located at the end of the fuel line. You can use a piece of wire to pull the hose and clean it. This has a tendency to gum up..
