Help john deere clutch driver
mike
12-05-2000 15:23:18
i need to pick on other peoples knowledge can i weld a cast clutch driver or should i start to look for a new one tried this question on general forum but they are only intrested in chev trucks so will try here to get some info
Bill Appleton
12-06-2000 08:43:21
 Re: help john deere clutch driver in reply to mike, 12-05-2000 15:23:18
Most all clutch drivers you will find at parts yards will aready be the same as yours. you have two options, take your crank and clutch driver to a machine shop and have your crank built up to the size of your driver. There are places that can build up drivers for you. You can also take alumium pop cans and cut shims about onehalf in. wide and 2 in. long with a L on the end. Push these between the crank and driver, put washer and bolt on.It does work and last for a long time.Bill .. Hopes that helps!
Wayne Swenson
12-05-2000 21:20:55
For a part that rotates and has a lot pf pressure applied to it, I would get a replacement. If your dealer is no help, look at the Green Magazine want ads or classifieds and you will find what you need. >Link
Also>Link try posting this to the John Deere forum.
T_Bone
12-05-2000 19:08:27
Hi Mike, We have three choices, flywheel, pressure plate and disc. Which one?
T_Bone
mike
12-06-2000 04:24:32
 Re: Re: help john deere clutch driver in reply to T_Bone, 12-05-2000 19:08:27
its a two cyilinder jd i guess it is the pressure plate as it spins between the two clutch discs
T_Bone
12-06-2000 08:32:01
 Re: Re: Re: help john deere clutch driver in reply to mike, 12-06-2000 04:24:32
Hi Mike, Thanks for explaining as I never worked on a JD. I would think it would be cheaper to replace the part than repair it as it will have to be surfaced both sides when your done welding. If the part is expensive then you have nothing to loose but right off the top of my head, I don't think it will weld worth a darn. Alot of built up stress on the surfaces.
What you might do is call a clutch rebuilder and see what they offer.
T_Bone
mike
12-06-2000 15:57:38
 Re: Re: Re: Re: help john deere clutch driver in reply to T_Bone, 12-06-2000 08:32:01
thanks for your info guys i think i will try to weld it and turn it down the tractor will never work hard and what have i got to loose as it is a 1929 GP parts are hard to find and cost the earth when you count the exchange for our buck thanks for your info and i will let you know on this site if i am succesfull
T_Bone
12-06-2000 17:22:28
 Re: Re: Re: Re: Re: help john deere clutch driver in reply to mike , 12-06-2000 15:57:38
Hi Mike, May I suggest a jig to hold the plate while you weld it. I don't know how much welding needs to be done but in any case thats what I'd do as warp would be a concern.
T_Bone
mike
12-07-2000 05:32:46
 Re: Re: Re: Re: Re: Re: help john deere clutch driver in reply to T_Bone, 12-06-2000 17:22:28
yess t bone i will jig it but it has to be able to be preheated as well to 400F as i dont think taking it of to put in sand to cool will be quite the thing also i need to weld both sides so i may have to go at it twice thanks mike
