Tool Talk Discussion Forum
compressor ?
jackbrit3
12-26-2004 08:47:59
when i am done with the compressor, and drain off the moisture, is it ok to store with pressure until the next use (month or two)?
Charles (in GA)
12-26-2004 18:40:20
 Re: compressor ? in reply to jackbrit3, 12-26-2004 08:47:59
Virtually all compressors are left pressurized by their owners with no problems. I kept a roll around portable pressurized for 30 years or so (still do actually) and my new 80 gal upright two stage 7.5 hp stays connected to power and pressurized all the time.
You won't have any problems
Charles
CNKS
12-27-2004 06:40:24
 Re: compressor ? in reply to Charles (in GA), 12-26-2004 18:40:20
If you don't drain, you get water accumulation in the tank and lines, best to drain once a day, unless you have an automatic valve.
CNKS
12-26-2004 12:35:13
I prefer that mine remains drained. I'm not saying that the small amount of water produced with one charge will cause much rust, but I like mine as dry as I can get it. An alternative is to use an automatic valve that drains each time it starts. If you leave yours plugged in, normal air leakage will cause it to run occasionally.
MAC,IL
12-26-2004 09:54:06
Mine stays pressurized all the time. Never had a problem yet.
