Tool Talk Discussion Forum
What is this welding rod?
Dick
12-25-2004 19:11:24
I got some welding rod at an auction and on the rod it looks like it says: Comatron 211 AC-DC, it very dark grey almost black.
Someone told me it could be a cast iron rod. Does this sound familiar to anyone? If so, could you tell me any hints to using it.
Thanks,
Dick
Fawteen
12-26-2004 04:33:58
 Re: What is this welding rod? in reply to Dick, 12-25-2004 19:11:24
Yes, indeed, that's Cast Iron rod. Had a welder friend of mine weld up a cracked wheel hub on my F14 with it. I'm a rank amateur, but it looked to me like he used it just like any other rod. Vee'd out the crack, drilled a stop hole at the end, and laid a bead in it. No pre-heat, no post-heat, no fooling around of any sort. Didn't notice what settings he used on the welder.
Weld has held just fine for over 5 years.
