Tool Talk Discussion Forum
fuse
jeffcat
12-22-2004 23:27:45
Time to put up another question. When I was in college and taking electronics classes there was a book. Now I don"t have it anymore but there is some information I need. There was a chart of wire sizes, say #28. This wire has 12 strands of wire in it. If you take one of those strands it would be a three amp. fuse. This is long ago and I am just guessing but You folks know what I am looking for. Someone got the info? Thanks Jeffcat
txblu
12-23-2004 17:38:35
 Re: fuse in reply to jeffcat, 12-22-2004 23:27:45
I remember when I used to fix TV's. In a tight, I 'd take one strand of lamp cord copper wire and wire across a blown fuse for troubleshooting.
With that said, fuses are purely thermal devices. They are made to melt wire in the event of a known value of overload or greater (sorta). This is the "fusing" current rating of the wire used, which for copper (not fuse material as stated by Gerald or Ralph) is about 10 times the usable current if using for electrical conductors, if it has plastic insulation that you don't want to melt (Ampacity da da).
In selecting and using a fuse, all sorts of things play into the equation of heat. At least with a commercial fuse, there is some sort of standardization as to the real current that will make it blow since it is in a housing and the housing only fits certain types of holders and all that.
Don't know where you are headed. Maybe you want to talk about that.
Mark
Gerald J.
12-23-2004 16:50:14
I know there was such a table for british wire sizes in the Radiotron Tube Designer's Handbook that dates from 1948.
The strand in a 7 strand wire is 8 sizes smaller than the total wire. So 28 would be made of 7 strands of #36. I'm thinking I remember #30 fuses at 15 amps, so 33 would fuse at 7.5 amps and 36 at 3.75 amps.
I don't remember that being in an amateur radio handbook since my first one in 1952.
Copper wire as fuses aren't as reliable as fuse wire because it takes so much greater temperature to melt copper. So fuses made with low temperature fuse alloys tend to be used a great deal more. With automotive fuses available for a few cents each in discount stores, its hard to take the time to figure out copper wire fuses. And events that heat the copper but don't melt it will cause it to oxidize and change size making it more sensitive.
Gerald J.
Ralph, Ohio
12-23-2004 13:32:19
This sounds like the kind of information that might be found in an Amateur Radio Operators Handbook.
