Hi Irv I used to be a general contractor and after framing 200+ houses and owning 25 nail guns over my life I learned the following about framing nail guns: buy a major brand such as; Paslode (they make some Sears, Makita, Dewalt and the newer Hitachi), Hitachi, senco, Porter Cable, Craftsman or Bostitch. Why? Because you can obtain a rebuild kit for them. Over time the valves and seals have a problem with wearing out, drying out etc. Try buying a rebuild kit for HF? However, before you buy a nail gun think about the nails, there are four types of nails, and they are not interchangeable, they are 21 degree, (plastic collated), 28 degree (some guns use paper some wire), 34 degree (paper), and coil (wire). Note: roofing guns use a different type of coil nail (roofing and framing are different animals altogether, two different guns two different nails). The higher the degree the more the clipped head, some building depts. won�t allow clipped head nails. Nail prices very between the different degrees also, I�ve always found the plastic 21-degree to be the most cost affective. And coil nails not much far behind. Rebuilding a gun usually takes less than a half hour and about $25 for the kit. Since I am no longer a GC I have found that the guns generally disappeared rather than broke. I currently own a porter cable framer and an antique Hilti Framer, a craftsman roofer, a porter cable 16 ga finish, a senco 16 ga finish and a sears 18 ga brad. Plus some staplers and flooring nailers. With the exception of 2 all of the nail guns I have ever owned were bought from pawnshops (I love to haggle); the smallest finish gun was $8, three years ago and has worked great. I store all guns in a cabinet (less dust), and oil on every use. I like to regulate at the gun, instead of at the compressor, less walking, more control. I have mistakenly dropped a bostitch framer and a hypoid saw about 40 feet, the gun went back to work, the skill saw went to the dumpster. I have also seen nails mistakenly? Shot through ankles, fingers, hands, feet, toes, legs, and ricochet through the back of an ear. I�ve watched a smart framer spend 2 hours digging a piece of plastic out of his eye ball because he didn�t have time to get the safety glasses out of his tool box. I hope this helped Dave
